MOT - sailed through
Re: MOT - sailed through
Postby GeoffSmith » Mon 09.09.2013, 17:44
Code: Select all
Year  miles  --CO--  --HC--
2007  35414  0.432%   69 ppm
2008  37599  0.423%   95 ppm
2009  39205  0.605%  112 ppm
2010  40874  0.477%  127 ppm
2011  41770  0.539%  120 ppm
2012  42296  0.512%   97 ppm
2013  44276  0.551%  106 ppm
Limit        3.500% 1200 ppm
And again..... apart for £2.25 for a new exhaust rubber.
Postby GeoffSmith » Thu 25.09.2014, 17:25
Code: Select all
2014  45439  0.558%  118 ppm
And again..... apart for not passing the closed loop emission limits (0.3% & 200ppm fast idle and 0.5% idle) first time around - see here.
Postby GeoffSmith » Mon 14.09.2015, 13:53
Apart from the cat overheating light coming on (what is that all about?) a mile before the garage (rectified by parking under a bridge because it was hissing down with rain and removing the lamp).
Code: Select all
2015  46397  0.580%  105 ppm
Postby TrevorB » Fri 08.04.2016, 15:05
Service and MOT done today and everything good with no advisories. Another good job by Maidstone Sports Cars.
Had to give her a wash on return, I think they had taken it rallying :lol: All good now :-D
Looking forward to another summer. :burnout:
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Closed Loop conversion
Kilimanjaro chip
Wannabe Princess
Postby Giniw » Fri 08.04.2016, 18:34
GeoffSmith wrote:Apart from the cat overheating light coming on (what is that all about?) a mile before the garage (rectified by parking under a bridge because it was hissing down with rain and removing the lamp).
I think the catalyst may overheat when your mixture is a little bit too rich ...
As far as I know, when the AFR is OK (14.7) the temperature inside the catalyst is at its nominal value.
When the AFR is a little too low the catalyst is much hotter, but if your AFR drops even more the temperature drops too.
So basically the catalysts overheats when it's just a little too rich.
But that would need confirmation from a specialist on that subject. And since your car has a catalyst that means it's closed loop so I don't know what can be done to address that... apart from removing the lamp indeed :lol:
Giniw
Postby Jamie N » Fri 08.04.2016, 19:54
TrevorB wrote:Service and MOT done today and everything good with no advisories. Another good job by Maidstone Sports Cars.
Just wow.... 8)
Monaco S2 #406
Jamie N
Seal God
Postby Rambo » Sat 09.04.2016, 02:11
Just wow.... 8)
Looks lovely Trevor, particularly the engine bay
Now you just need a decent tool kit :wink: :twisted:
Postby GeoffSmith » Sat 09.04.2016, 10:23
That logic works well, but I think it only applies to Japanese spec Elans. Mine appeared to have lost its cat a long time before I got it so I'm pretty sure it's a dodgy connection somewhere. Funnily enough, it hasn't reoccurred since my fix. :lol:
Postby TrevorB » Sat 09.04.2016, 13:56
Rambo wrote:Now you just need a decent tool kit :wink: :twisted:
Silly me Mark, and I thought it was all a distant past :-D :wink:
But I am still looking :)
Trevor
p.s. thanks for the comments
:cheers:
HiSpec front brakes
PNM rear brakes
Aluminium radiator
Kilimanjaro chip
Wannabe Princess
Postby Giniw » Sat 09.04.2016, 15:03
GeoffSmith > OK :-D
Glad it is nothing alarming after all :)
Giniw
Postby GeoffSmith » Thu 06.08.2020, 17:13
Passed! :bananasex:
Why don't MoT certificates now give the emissions data? How are we expected to know when something is drifting the wrong way and needs to be looked at? Is this progress?
Postby Saltire » Thu 06.08.2020, 17:29
Really? My last one did - I got a separate sheet with all the readings. My MoT date was extended to November, but I’ll be taking a particular interest when it comes round.
Postby dapinky » Thu 06.08.2020, 18:41
GeoffSmith wrote:Why don't MoT certificates now give the emissions data? How are we expected to know when something is drifting the wrong way and needs to be looked at? Is this progress?
The only time I know where the emissions (& brake efficiency) print-outs are not provided are where they didn't meet the required standard, and a PASS was issued.....
For a failure, they have to tell you (so it can be fixed!) - but if your emissions were tested in an unorthadox manner that would prevent the machine (as it's all computerised these days) from accepting the results without "Computer says no!", then that may explain it.....
.... eg, I know that you have had 'discussions' in the past about the testing standard being for the engine not the car - but if the tester accepts that, he can't then enter the figures as tested, because the 'puter would shout "FAIL".......
Postby Fredjohn » Thu 06.08.2020, 18:59
I've had a print out of emissions when it passed.
Postby Simon_P » Thu 06.08.2020, 21:22
The MOT paperwork is effectively optional and the test centre have to provide their own ink and paper since they stopped having pre printed certificates.
I've always had to ask for the brake efficiency numbers since it is a pass or fail and usually hand written. The emissions are usually on a printout provided with the certificate. Last week when the Blue Car passed I was asked if I wanted a copy, I presume because most people don't know or care what it says and do nothing with it other than throwing it away.
Postby woody » Sat 17.10.2020, 13:19
Mine had MOT today and sailed through with no advisories - hooray :clap:
Cheers,
Woody
woody
Postby HJ2 » Sat 17.10.2020, 20:43
Congrats! :cheers:
Postby GeoffSmith » Wed 13.07.2022, 12:05
Off the road since last August but all she needed was new tyres, a battery and removal of the low washer bottle module… but I really must do more than 420 miles this year. :bananasex:
Postby Rambo » Wed 13.07.2022, 14:42
Geordie garage queen :poke:
Postby GeoffSmith » Thu 13.07.2023, 15:40
Rambo wrote:Geordie garage queen :poke:
:oops:
Return to General
Users browsing this forum: Bing [Bot] and 4 guests
