by theelanman » Mon 21.07.2014, 17:07
by Enright » Mon 21.07.2014, 17:29
Keep an eye out for a Gem or a Gnome and you might stand a chance. The Avon will give you an "interesting" power to weight ratio!
Neil
- Modificator
by cliff » Mon 21.07.2014, 20:00
Would be more interested in this:
http://www.silverstoneauctions.com/1976 ... 3-jump-jetEven has the IV (AC) Sqn markings - happy days!
91 Lotus Elan SE Turbo
07 Alfa Spider 939
cliff
by theelanman » Tue 22.07.2014, 07:37
by cliff » Tue 22.07.2014, 10:34
theelanman wrote:The aircraft comes with the Rolls Royce Pegasus Mk103 engine, not currently fitted to the aircraft but in a wheeled transit stand. For display purposes a photo decal engine blank is fitted in the intake as well as a full set of engine nozzles
Fitting a Pegasus is no problem, wing off, pegasus in. Ideally find someone with the hands of a 5 year old, if not, cue cuts, bruises and a serious attack of tourettes. When all connected, wing on, tie downs and away it goes.
07 Alfa Spider 939
cliff
by Fredjohn » Tue 22.07.2014, 10:38
Bit like fitting an M100 cambelt then........
Return to Off Topic Area
