Broken alternator Adjusting Bracket
Postby petestubbs » Fri 14.03.2008, 21:54
Hi,
Can anyone advise where I might get an alternator adjusting bracket please, mine has broken?
Its the small metal bracket that the alternator slides around in for adjusting the alternator belt.
It can be seen above the alternator when looking into the engine from above the alternator belt.
Would I need to go to Lotus, Isuzu or, better still, is there a unipart type number?
Many thanks in advance
Pete.
petestubbs
Postby petestubbs » Fri 14.03.2008, 23:13
I dont know if i described it very well but it is the bit painted orange in the diagram;
alternator bracket.jpg (34.71 KiB) Viewed 1498 times
petestubbs
Postby mikeydude » Thu 20.03.2008, 21:43
It would not be difficult to make one by the looks of things, if it can be welded then send it to me and I will sort it as I have a mig welder
mikeydude
Postby petestubbs » Fri 21.03.2008, 12:38
That's a very kind offer, many thanks, I will let you know if I cannot find a similar item somewhere
petestubbs
Postby Sy V » Fri 21.03.2008, 17:00
Pete
It wouldn't have to be exactly the same so any scrappy should be able to help you.
