by Gazza » Thu 24.07.2008, 10:50
Has anyone got a spare set of Oil Cooler Pipes, old or new laying around that I could borrow and use as a template. So I can get a set made up from s/s Braided hose without having to remove mine from the car, keeping it off the road for a while.
I will return either by post or in person at the 60th anniversary.
A100K0032F and A100K0033F
Cheers Gary
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
by Enright » Thu 24.07.2008, 12:30
Probably, but can you post a pic of the ones you mean just so that I can make sure?
Neil
- Modificator
by dapinky » Thu 24.07.2008, 13:11
Gary,
I ain't got any, but have you tried Pirtek?
They do a mobile pipe making/fitting service (Geoff has used them for PAS pipes).
- LEC Administrator
by Gazza » Thu 24.07.2008, 15:56
Cheers for the replies lads.
Neil if you go into the Elan parts manual, under cooling system, page 337. They are the only 2 pipes that attach to the oil cooler and then go somewhere else
Unless someone can post this picture for me
Chaeers again, Gazza
SOLD
Gazza
by Gazza » Thu 24.07.2008, 16:05
They should also have some foam covering.
SOLD
Gazza
by router » Fri 25.07.2008, 11:25
These are the pipes in question.....
Gazza wrote:Cheers for the replies lads.
- Attachments
Doc1.doc
- (57.5 KiB) Downloaded 280 times
router
by GeoffSmith » Fri 25.07.2008, 16:36
Do you want me to move this to the "Group Buys" section Gary?
- Kitty Fiddler
by Gazza » Mon 11.08.2008, 17:44
Neil
Any sign of these pipes or anyone else?
Geoff, I have asked Sinclaires about discounts but to no avail I'm afraid. So once they are done you will be able to order through them.
Still need to get a price for Ailwyn, once I have the pipes in my hand.
Cheers, Gazza
SOLD
Gazza
by Enright » Tue 12.08.2008, 18:06
Ah no. Sorry, I don't have those.
Neil
- Modificator
by Gazza » Tue 12.08.2008, 18:28
No problem Neil.
Cheers anyway, Gary
SOLD
Gazza
by Ade » Tue 12.08.2008, 20:34
Gazza
I think I have the pipes you need I had them changed a few years ago, don,t know why. I tried to look at the pics but just got mush, probably my fault. Ill check the manual to double check if they are the ones. There yours to borrow if they are.
Ade
Ade
by Ade » Tue 12.08.2008, 20:44
Gazza
I have the pipes you need. There yours to borrow if you still want them.
Just one difference one of the pipes begins with a B not an A rest of the no. is the same.
Ade
Ade
by Gazza » Wed 13.08.2008, 17:43
Ade
You have a PM
Gazza
SOLD
Gazza
by lotusgirlmarie » Thu 14.08.2008, 20:52
The hoses are an 8AN with a 14 mm banjo fitting on the cooler side. The car side has a funky hydraulic fitting on it. Should be an easy fab
lotusgirlmarie
- Goddess
by Gazza » Wed 03.09.2008, 18:09
Why is nothing easy?
The company Sinclaires are using to get these pipes made in Braided are having problems. Something to do with the fact they need to keep the metal pipe which is causing problems. They can't take these pipes apart because they are not mine, they are Ade's.
Why can't these pipes be flexible with just new fittings on the end, do they have to have a ridged pipe one end?
Gazza
SOLD
Gazza
