by CJ101KT » Sat 07.03.2009, 22:45
Please slap me on the wrists for starting a new topic regarding dump valves but I have been searching posts for some time and still find myself unclear as to whether I should invest in a dump valve for Trigger or not? I am one who has always like the chattering sound that the turbo makes upon gear changes but am also becoming more aware of the reason and damaging properties that it may incur over time?
I would be interested to know peoples thoughts on yes or no to installing a dump valve and also how to install one, which type to get and how to avoid sounding like the rest of my age group driving round town all night ... i.e pimped up Saxo's lol. I am aware that alot have got a Baileys dump valve, are these regarded as the best? and where is best to get one from?
Sorry for all the questions but afraid I am on a learning curve and would like to pick everyone's brains
Thanks in advance, CJ
CJ101KT
by John_W » Sat 07.03.2009, 23:09
As to the reasons for fitting a dump valve, see
here and
here.The second reference leads to some threads which should answer your other questions. (Mind you, I see it also leads to some of our famous dead links/deleted topics on the forum.)
- Heid-bummer
by CJ101KT » Sat 07.03.2009, 23:30
John_W wrote:As to the reasons for fitting a dump valve, see
here and
So there is still no certain answer as to whether the turbo stalling action is indeed bad or that a dump valve could leak and hinder the situation? Also, demon tweeks sell a kit for £32? I have read it can cost about £100?
CJ101KT
by CJ101KT » Sat 07.03.2009, 23:44
CJ101KT
by John_W » Sat 07.03.2009, 23:49
CJ,
The "kit" which Demon Tweeks sells is the fitting kit (ie the T-piece and bits of hose). You still have to buy the dump valve itself, which will be almost £100 I think.
Yes, you're right, there are still people who think it's necessary and people who don't.
I've got one, but I'm not convinced it's doing any good. However it's properly fitted and Elanscan logs show the boost to be OK, so it's not doing any harm either.
- Heid-bummer
by CJ101KT » Sat 07.03.2009, 23:54
John_W wrote:CJ,
What is the installation like for a novice lol? I could be know as a Computer Geek but still learning on becoming a Mechanic Geek if there is such a thing. I have sourced the two types of valves available from Bailey's and the fitting kit, do you have the re-circulation type? I am not sure whether I want the woooosh sound or not as I like the stock chattering sound and don't want rid of some sound altogether lol ...
CJ101KT
by Jimmer » Sun 08.03.2009, 18:56
Like CJ, I'm interested to know if there's much difference between the dump valves on the market.
The Baileys seems the easiest to come by but does anyone have good / bad experiences they can share with these or any other model?
Also, can anyone explain the difference between the venturi type and the regular one?
Jimmer
by GeoffSmith » Sun 08.03.2009, 21:06
Watch your terminology:
Dump valves open solely due to excess pressure.
Blow off valves are opened by the vacuum produced at the inlet manifold.
I would imagine the venturi/trumpet is there purely to let more people know you have a chav whistle!
Still not convinced of the merits for stock/medium boost levels.
- Kitty Fiddler
by CJ101KT » Fri 20.03.2009, 21:30
It would be nice to get an expert opinion as to whether our cars would benefit from a dump valve or blow off valve, which ever we are discussing. The stalling sound of the turbo sounds good but if it is doing harm I would like to fix it especially if there are benefits from such improvements. Not sure I'm going to pay out of something that is a bit of an unknown and also no idea how to install ones yet.
CJ101KT
by lotos » Fri 20.03.2009, 21:37
I didn't know there was dissent on this issue - from everything I've read and been told, the valve will extend the life of your turbo.
lotos
by CJ101KT » Fri 20.03.2009, 21:40
lotos wrote:I didn't know there was dissent on this issue - from everything I've read and been told, the valve will extend the life of your turbo.
Dissent lol. Yes I have read that but also read that it could allow loss of air too? I'm not keen on getting one unless I know which it will do.
CJ101KT
by John_W » Fri 20.03.2009, 21:49
CJ,
Have you seen the info from the old LEC site, written by Doug?
Have a look
here.John
- Heid-bummer
