Idle speed racing away on start up
Postby M100TURBOFR » Wed 18.12.2019, 12:17
Hi
Have just had starter motor and alternator refurbished. For access to and removal of both starter and alternator I naturally removed the prongeron. I also removed the plenum for better access to the top starter bolt. I also removed the throttle body in order to clean it properly. Having reinstalled everything, the engine fired up first time but no idle speed at all. It races away as though I was pressing the accelerator. What have I done wrong? Help would be appreciated.
M100TURBOFR
Re: Idle speed racing away on start up
Postby Steve A » Wed 18.12.2019, 12:43
Sounds like you have a leak from the plenum, does it settle down after a while ?
Postby M100TURBOFR » Wed 18.12.2019, 13:28
Steve
Thanks for your reply. Don't know if it settles down as frightened to let it race away too much.
M100TURBOFR
Postby Steve A » Wed 18.12.2019, 23:01
viewtopic.php?f=38&t=27477&hilit=vacuum
I'm just thinking this sound similar
Postby M100TURBOFR » Thu 19.12.2019, 09:40
Steve Hi
Thanks for link. Will have a look at vacuum connections.
M100TURBOFR
