Car troubles
Car troubles
Postby Empire Green » Sun 12.07.2020, 11:56
My beloved Elan failed yesterday for the very first time :shock:
Just serviced the car with new spark plugs, new ignition cables and installed the Everest chip (thank you Alan for the stunning results)
Was driving a couple of hundred kilometers after the service and while cruising the engine started hesitating.
Felt like a failing cylinder... few kilometers later the engine totally failed :banghead:
However, I could simply start again, drive a few minutes and had the same problem.
Thank God I got home.
This morning I tried to start.
The engine ignites and instantly stops again.
When I try to restart, the starter motor goes off, but nothing more...
Any ideas ?
Thank you all !
Empire Green
Re: Car troubles
Postby tb10 » Sun 12.07.2020, 14:04
I’d remove the Everest and try it without.
tb10
Re: Car troubles
Postby RonR » Sun 12.07.2020, 14:35
If you don't find any obvious cause, here's something to look into:
A friend of mine with an Esprit had a very similar problem to yours. After a period of rough running the car would start normally then stall.
In the end it was traced to a catalytic converter which fell apart internally and blocked the exhaust.
Re: Car troubles
Postby GeoffSmith » Sun 12.07.2020, 14:53
RonR wrote:If you don't find any obvious cause, here's something to look into:
Good suggestion Ron. If the cat was getting close to failing, the extra stress of having an Everest may have accelerated the blockage.
Re: Car troubles
Postby Rambo » Sun 12.07.2020, 15:00
First of all I would do the "paper clip" test and see if there are any stored error codes.
Secondly, I would disconnect the battery, leave for a few minutes and see if the ECU has been reset (NB you will lose ang stored error codes)
Thirdly, I would try removing the Everest chip temporarily as John has suggested to see if the problem goes away. It may well be that the extra boost has caused cat. problems as others have eluded to, assuming, that is, you have an S2 ?
Re: Car troubles
Postby Simon_P » Sun 12.07.2020, 15:45
Simpler still - check that the fuel pump is priming before trying to start and check that you are getting a decent spark.
As a guess it I'd start with HT failure (coil pack) , followed by lack of fuel - fuel filter or fuel pressure regulator.
Re: Car troubles
Postby Empire Green » Sun 12.07.2020, 18:22
Great Guys !
Thank you for the feedback.
I'll try to restart without the Everest chip.
Lets hope it works (fingers crossed)
It's an S2, do they have often problems with the Everest chip ?
Best Regards !
Empire Green
Re: Car troubles
Postby Brit-Car-Nut » Sun 12.07.2020, 18:52
No common problems with the S2 but to install the Everest Chip, you need to make sure you have fully seated the adapter into the chip slot. The levers must return to vertical which will let you know the adapter is fully seated.
Re: Car troubles
Postby Empire Green » Sun 12.07.2020, 18:53
Ok, without the Everest, it starts perfect
Now, some further investigation... how come, my S2 doesn't respond correctly on the chip ?
If anyone has any ideas, please tell them, I'll check Alan`s site meanwhile.
Thank you for all the response !
Empire Green
Re: Car troubles
Postby Brit-Car-Nut » Sun 12.07.2020, 18:54
Read the previous post!
Re: Car troubles
Postby Empire Green » Sun 12.07.2020, 19:02
Brit-Car-Nut wrote:Read the previous post!
It was firmly attached, 2 slots perfect in place :bonk:
Empire Green
Re: Car troubles
Postby Rambo » Sun 12.07.2020, 19:18
No idea why but usually if its working OK before you change something it's usually the things you have changed that are the route cause of the problem. Part of Sod's Law :?
Re: Car troubles
Postby Empire Green » Sun 12.07.2020, 20:13
Solved !
built the chip out, started ok, built him back in, started more then ok... don't know what is was, but she drives again :bowdown:
Will visti the local Lotus dealer to do a total check up before we leave on a road trip.
All the best !
Empire Green
Re: Car troubles
Postby Rambo » Sun 12.07.2020, 20:58
Good news :wink:
