Generaly Help needed... Softtop, Stowage, Trunk....
Postby Don.Hasi » Sun 27.08.2006, 11:38
Hello totgehter,
a have several problems like usually if I think, ok, its only a job of half an hour :roll:
So, I know from the start, that my car must have had an accident at the back although the fcuking seller didn´t mentioned it :evil: But all items under the surface dide mak a good impression... rattles in the steering and other thingies just discovering in the nearer past Image
Ok, all my faults... :roll:
So please help me to decide, wether Ina II must go to the scrap dealer :cry: or I can rescue her Image
As I stated in former times... don´t repair what is not in pieces Image the softtop haven´t fit properly... I have driven all the winter long with it but now it seems to leek more... so I thougt do to the easy job...
You have linked several times to the sefvice notes with 2 M12 100 and 1 M12 80mm bolts. Theses bolts doesn´t fit, although the same dimensions are called in the kia service notes :shock: or I dont´t know where to mount them :roll: But anyway, just in case I would know which ones and where... I wouldn´t get the method to adjust...
which bolts do I have to unbolt for adjusting the construction? Please, I have read any comment to this topic, but I don´t understand it... Is there an opportunity to get an instruction for beginners, for stonecutters under us to cut it in the meantime? Image
Does the softtop have to lie on the frame without pressure? Mine stands to much in the air in the front and too much on the stowage....
Then, its not all, the stowagelid has to much pressure too :( If you open the lid it snaps proper of, but you need power to close it again, cause the hinges have in myview no the right angles... But to make it complete, the hinges are destroying the stowagecabin :cry: I want to adjust them too, but there are no opportunities I have seen... could the hinges only be twisted?
For reaching them I have demounted the trunklid, for noticing damages on the trunklid by remounting it before by any idiots who think a bolt must be closed until it reaches the surface on the other side :evil: :smt070 :evil: ... but I can´t get open the counter bearing (the thing for being sure, that trunk and stowage are not open to the same time)
Could you HELP ?
Thanks for any advices in advance
Here is the link for more pictures before Tony gets any heartattack belonging to the traffic :wink: Click HERE
Don.Hasi
Postby Don.Hasi » Tue 29.08.2006, 19:31
Perhaps a slight advice? :( :cry: :(
Don.Hasi
Postby Neil D. » Wed 30.08.2006, 10:22
have you tried adding shims ( packaging ) between the hinges and the cover Plate ?
Neil
Neil D.
Postby Don.Hasi » Wed 30.08.2006, 18:35
:-) THX for answering.
No I haven´t tried it... Shouldn´t the coverplate in that case comes to far to the cockpit? I think the ending to the B-pillar is just fine. And the greatest problem, I can´t get the hinges out there... I have tried it, but the counterpin in the trunk was not to convince to get off :evil:
Do you have any shims there?
I know that shims are a valuable Lotus-solution :roll: so, it would be a possible way with sticking the principles of the car Image
Do you have the gap of the softtop on the frontframe too?
And do you ever have trimmed the seals in the right position?
Greets
Don.Hasi
Postby Andy_J » Wed 30.08.2006, 22:25
Had a similar proble mith the soft top hood on My Elan when I bought it.
You need to remove the hinges for the hood cover an shim the top of the bracket. It is not easy to do, you need to manipulate the hinges to release them from the counterpin on the boot hinges.
As for the soft top there are good instructions in the workshop manual, however I am sure it was m10 bolts I used to adjust the soft top ans not the m12's refered to in the manual
90H BRG SE 48,000 Miles
Andy_J
Postby Don.Hasi » Wed 30.08.2006, 22:49
Hi Andy,
very interesting... I have used M8 bolts :shock: But I don´t understand the sense of this adjusting... There are 2 90mmlong bolts who keep the Softtop in the box of the b-Pillar, right on the subframe... with the m8 or in your case m10 bolts one can adjust the position in all 3Dimensions but you can fasten the 90er bolts then again Image
so, what is it about? Adjust to say: hey, in this way should it be, but i have to lock them in the old way, cause there is no space to move AND lock them.. Image
Or is there a special trick?
With view to the hinges... I have feared for those words Image
ok, then will i have a look for right fitting shims...
THX
Don.Hasi
