Elise Rear Lights (again!)
Re: Elise Rear Lights (again!)
Postby theelanman » Fri 02.03.2012, 15:48
jHamshaw wrote:
theelanman wrote:
J46_MAV wrote:They did fit straight in, no fiddling about, using the same mounts. They can be swapped over directly with the originals.
Could you let us have the info for the place that did them as i certainly would like a chat with them about producing a pair
forum.lotuselancentral.com/viewtopic.php?f=35&t=17220&p=231400#p231412 :bonk:
Nope.......
Name, address, telephone number, website details -
none of which have appeared on that thread since i last looked....or this
Any chance of any of the above mentioned info?
Postby Aoki Magic Pants » Fri 02.03.2012, 17:15
theelanman wrote:Nope.......
viewtopic.php?f=80&t=10208&hilit=rear+Light+Pods
^ This seems to be the point when most people who have them acquired the rear light conversion.
Aoki Magic Pants
Postby jHamshaw » Fri 02.03.2012, 19:01
Agreed. There just aren't any any more. What there were, were one-offs and specials.
It also appears that to use Elise rear lights, the eyebrows have to go, making this a "plug and play" impossibility.
Evora (if they're smaller) or these Hella units look a possibility, but I reckon it's still a project someone needs to start from scratch, making an exact OEM fit moulding and mounting for both M100 and Renault GTA's if "volume" sales are needed to make it worthwile...
http://www.s-v-c.co.uk/category/mix-match-lights/
jHamshaw
Postby Aoki Magic Pants » Fri 02.03.2012, 20:03
jHamshaw wrote:It also appears that to use Elise rear lights, the eyebrows have to go, making this a "plug and play" impossibility.
What do you mean by this? My Elise pods were a direct nondestructive swap, even the wiring. They probably took no longer than 10 minutes to install each side and can be just as easily switched back.
If you can find somebody who can make them again, perhaps you should see if there's enough support to make a group buy worthwhile for them?
Aoki Magic Pants
Postby lotusgirlmarie » Fri 02.03.2012, 20:05
The early ABS prototypes I built which are floating around the UK somewhere did not need any eyebrow removal or any modification of any kind. They were a drop in replacement for the Renault lights. Only the complete rear valance needed removal of everything in addition to the new plate light.
lotusgirlmarie
Goddess
Postby theelanman » Fri 02.03.2012, 21:43
Still doesnt tell me who & where j46_mav got his done......
Postby cliff » Sat 03.03.2012, 00:33
Maybe this helps:
viewtopic.php?f=30&t=20038
Drop chrisP a PM
viewtopic.php?f=85&t=19099
or Mattdon
91 Lotus Elan SE Turbo
07 Alfa Spider 939
cliff
Postby theelanman » Sat 03.03.2012, 03:04
cliff wrote:Maybe this helps:
Drop chrisP a PM
or Mattdon
Nope.....
Guess j46_mav is the only one....
Postby J46_MAV » Sat 03.03.2012, 12:08
I'm afraid I can't shed any more light on the source of these 'pods' other than what's on the original threads.
To summarise, I bought them from another LEC member about 2 years ago so am not best placed to vouch for the original source. From the discussions on this forum, it looks like they were made by Lotus Girl Marie some years ago as a one-off (or maybe two or three). She has stated that there is no pattern/mould in existence that could be re-used.
91SE in Pacific Blue
44,000 miles
Bought in December 1991 from Mann Egerton, St Ives
J46_MAV
Postby Aoki Magic Pants » Sat 03.03.2012, 12:35
J46_MAV wrote:I'm afraid I can't shed any more light on the source of these 'pods' other than what's on the original threads.
Same here, I got my pods from ChrisP about 2-3 years ago. I guess there were only half a dozen made or so?
Didn't Surfboardfiller sell his mould for the plinth to somebody else on this forum? Perhaps Mattdon?
Aoki Magic Pants
Postby jHamshaw » Sun 04.03.2012, 14:24
Only that they may have been too big to fit into an "adapter" moulding, with the eyebrows still in place - it would now appear that this is not the case and I stand corrected....
jHamshaw
Postby lotusgirlmarie » Sun 04.03.2012, 19:14
I'll make this easy. I made them. Almost 10 years ago. Sold them on to a lad in the UK who had them painted red. Not sure why but he then sold them on and now their black and on a beautiful blue machine enjoying life. I only made the one set as I really hated the OEM lights. They were on my car til I started my rear valance run. The one set was made from ABS and I heat formed sheets of ABS to make them. There are no moulds, bucks, drawings, schematics, dimensions or measurements of any kind that I made when I did them. I used the OEM lights as a guide and my own artistic ability and aesthetic taste to come up with the final product.
lotusgirlmarie
Goddess
Postby chrisP » Mon 05.03.2012, 13:57
Thanks for the link Clive
If it helps at all have a look at this thread: http://forum.lotuselancentral.com/viewtopic.php?t=10208&postdays=0&postorder=asc&start=100
I have two panels and some pods in the shed, although the pods are already sold to Clive. I have made a few over the years at peoples requests.
Best Regards
chrisP
Postby rip » Mon 05.03.2012, 16:24
Aoki Magic Pants wrote:Didn't Surfboardfiller sell his mould for the plinth to somebody else on this forum? Perhaps Mattdon?
Correct on both counts.
Postby HansM » Tue 05.08.2014, 02:34
chrisP wrote:Thanks for the link Clive
Best Regards
Hi Chris,
Just became a member of the LEC forums but watched it for many years.
I own a S2 car which got shunted last week, both rear lights are damaged.
And now I am looking for alternatives and was wondering if you still do the rear pods.
Would be most helpfull if you could make me a set.
Best regards,
Hans
HansM
Postby chrisP » Wed 13.08.2014, 17:26
Hi Hans
Sorry I have only just seen your post, I should be able to help you - PM sent....
chrisP
Postby theelanman » Wed 13.08.2014, 17:37
chrisP wrote: I should be able to help
production run of rear plinths????
:-D :-D :-D :-D :-D :-D :-D :-D :-D :-D :-D
Postby chrisP » Tue 19.08.2014, 17:09
Probably not a production run - they are too labour intensive, but more made on request :wink: Drop me a PM if you are interested in a panel or pods
chrisP
Postby cliff » Mon 01.09.2014, 21:17
Just for info a couple of pictures of Chris P's pods.
After painting.
Fitted.
07 Alfa Spider 939
cliff
Postby lotusgirlmarie » Tue 02.09.2014, 07:39
The first round tail light conversion I made and later sold on when I made the Fed rear valance. The first set was a direct replacement for the OEM lights without any removal of the eyebrows or cutting of any sort. Built in ABS plastic circa 2003/04. They were the first ones and only set I made.
lotusgirlmarie
Goddess
