Bonnet badge replacement
Postby r19 » Sun 28.09.2008, 18:17
Some moron has tried to get my bonnet badge off with a screwdriver and bent it and broken the enamel.The car is a series 2.The underside of the bonnet has two black rubber cylinders attached to the badge.I am struggling to get these off and when i do will the badge release also are these rubbers available to fit a new badge
r19
Re: Bonnet badge replacement
Postby nitroman » Mon 29.09.2008, 23:45
Sounds to me like someone placed the protective rubber cylinders back on the two threaded posts to hold your badge on! All 3 M100s I've owned had nuts threaded onto these posts holding the badge on.
nitroman
Postby M100 TWO » Tue 30.09.2008, 09:23
sounds like someone has used rawle nuts use a pair of point nose pliers and unscrew the whole rubber tube there is a nut bonded inside the rubber
diff
M100 TWO
Postby r19 » Tue 30.09.2008, 17:00
Thank you M100 TWO.They were as you described and the badge is now removed.I have just bought my series two and am in Poole so may see you around.
r19
Postby M100 TWO » Tue 30.09.2008, 18:50
glad it worked out OK do not buy the heritage badge it has the wrong PCD
diff
M100 TWO
Postby Ade » Tue 30.09.2008, 20:21
Hi,
When I replaced my badge, I put 2 rubber washers between the body, and the nuts, tighten against the rubber, to hold the badge tight without pulling it into the paint.
Ade
Ade
Users browsing this forum: SemrushBot and 2 guests
