Corrosion Issues
Corrosion Issues
Postby Specky » Tue 28.10.2008, 23:07
A new thread for Corrosion related Issues...
I've some pertinent information and pictures to follow... When I get a free 1/2 hour...
and a bit of information on repairs by Pinky too... :wink:
Re: Corrosion Issues
Postby dermotbell » Sat 01.11.2008, 20:59
Any developments?
Dermot Bell
dermotbell
Postby Monty » Sat 01.11.2008, 22:03
I found some rust in the corners at each end off the sills when i was fitting the Roll Hoops, it wasn`t bad so used rust killer on some underseal.
Postby Specky » Sat 01.11.2008, 22:04
dermotbell wrote:Any developments?
In all honesty... Not really...:roll:
But here goes...
After years of reading numerous adverts saying Élans don't rust I thought that a little advice would help potential buyers and sellers make a more informed decision...
Firstly.... YES these cars do corrode... and what's more... they suffer from several other types of corrosion
With each type corrosion that may be evident it could also confirm other types may be present...
So here is the first find...
The Élan is notorious for leaks. So it came as no surprise to see heavy exfoliation corrosion on the aluminium seat spacers which was also a tell sign that the inner side sills would be heavily oxidized
So here is a couple of pics to Re-enforce a potential Problem
As for repair, I'm unsure if full replacement is possible, but a minor rework would be possible
Postby dermotbell » Tue 04.11.2008, 21:51
Not surprising I suppose that the aluminium has oxidsied when you consider the problems the S1 Elises had. On some early S1 models they attached a rubber mat to the floor, this trapped moisture and the resulting oxidation caused actual holes to appear in the floorpan when the mats were lifted. :cry:
Dermot Bell
dermotbell
Postby Specky » Mon 04.05.2009, 22:04
After stripping two tubs down I think I've worked out an external check to tell if the inner cill metal work is corroded... (No stripping required)
under the cills where they meet the floor there are a series of fastners these run the full length, if they're corroded the inside will be...
Check yours and scare yourself cilly
Postby ovi » Tue 05.05.2009, 10:26
Good thread! :banana:
I will check mine! :shock:
ovi
Postby Specky » Tue 05.05.2009, 11:38
I'll do some pictures... I like pictures...
Check these fastners.... Mine show very little corrosion, but wait till you see the inside...( So any corrosion on the fastners is pottentially bad)
Another angle
The fastners tally up perfect, A point of note there doesn't seem to be any corrosion on the inside of the cill, (Not yet any way)
Check the front of the Chassis, lower tub mounting area and bolts
This could be curtains
I think so... A shot from inside the tub where your right foot normally goes
