boot lock
boot lock
Postby markiep » Tue 24.03.2009, 15:20
Anyone know how to or could recomend someone (garage etc)to get my boot lock back on.
i have the barrel with a piece of rubber around it & a piece of metal which fits around
the barrel sort of horse shoe shaped although i'm not sure if it goes on from the top or bottom. i know, i'm a philistine. i've owned four others but can't remember what it looks like all put together (i bought this one with the lock out) i've fiddled around with it to no avail, did i mention i'm also useless at fiddling around with stuff.i know, i've bought the wrong car.also the bumper has dropped on one side i think due to the adjustable suspension being to low at front & bumper bottoming out on floor any recomendations of places that could sort this apart from main dealer?
cheers mark
it doesn't matter what temperature a room is it's always room temperature.steven wright (not to be confused with steve wright)
markiep
Re: boot lock
Postby bobbrown » Tue 24.03.2009, 21:13
This is a lot easier if you remove the boot (trunk) lid and set it on a table down side up.
You can then remove the rubber grommet and all should be revealed, it is straight forward all be it a bit fiddly.
Pacific Blue N/A
Re: boot lock
Postby dapinky » Tue 24.03.2009, 21:32
Mark,
How much of a rush are you in?
You about at the weekend?
Re: boot lock
Postby Jackonicko » Tue 24.03.2009, 22:20
Straightening up the rear bumper is quite easy - just undo the bolts, get a couple of chums to hoik it up, evenly, and tighten them up again.
Jackonicko
Re: boot lock
Postby markiep » Wed 25.03.2009, 13:41
thanks for all the advice guys.dave you have pm.
markiep
