CREAKY HARDTOP
CREAKY HARDTOP
Postby Bolsom » Sun 19.04.2009, 08:26
My hardtop which I have had for about 8 months has started creaking. It seems to come from the around where the top is held by the lefthand front clamp.
Has anyone had this problem and know if this can be adjusted/cured? I have hesitated to play with it in case I make it worse.
I also get a fair bit of wind noise and leaking at this point. I am going to adjust the window angle to ease this problem. I have also thought of making a softwood
former to to mould the sealer around ths area. Has anyone a better method/idea?
Colin
Bolsom
Re: CREAKY HARDTOP
Postby MattDon » Sun 26.04.2009, 23:30
the creaking is normal after a settling in period, you just need to tighten things down slightly, i put a couple washers under the clasp grip at the front that attatches to the windscreen, also if i remember i slightly enlarged the holes in the rear clasp grips which gave a few more mill movment which was enough to tighten it down nicely.
if the wind noise it at the front i bet once its tightened it will go, but if your talking about around the window sills i have the same issue and have been thinking about a solution, my first port of call is making sure my windows are right, then im going to look at either a rubber seal to go around the outside to allow better air flow, then id look at pushing the seals out a little, but i cant see it coming to that.
dont worry about the hardtop, i was scared silly but its very simple and theres not much to go wrong
please use email for contact
MattDon
Re: CREAKY HARDTOP
Postby ektrolleyboy » Mon 27.04.2009, 08:09
Vaseline!!! Tried on my M3 cabriolet, Ferrari 355 GTS's and SLKs works every time!
Pacific Blue-LOTUS ELAN S2 # 036 / Hot Orange-MINI COOPER S CABRIOLET
ektrolleyboy
Re: CREAKY HARDTOP
Postby GeoffSmith » Mon 27.04.2009, 16:24
Definitely NOT vaseline which is petroleum based and will ruin seals. Try Silicone grease if you must.
Re: CREAKY HARDTOP
Postby ektrolleyboy » Wed 29.04.2009, 11:48
Can't comment on ELAN seals, but I never had any trouble and it was Ferrari who reccomended the fix!
But that's not an educated statement just one of experience, so maybe in the long term Geoff might be spot-on...
ektrolleyboy
Re: CREAKY HARDTOP
Postby Beryl Toolkey » Wed 29.04.2009, 12:57
Latex DOES NOT like petroleum jelly.
The solvents in vaseline will rot latex, but I do not know the composition of the seals - if they contain natural rubber, do not use vaseline.
Someone else has suggested Silicone grease - and this is what we recomend and use use in the hospital ;-)
If you cant find a specialist seller, and you can cope with the percieved embarassment, get some KY jelly down at Boots.
Beryl Toolkey
Re: CREAKY HARDTOP
Postby DaveB » Wed 29.04.2009, 13:19
Beryl Toolkey wrote:If you cant find a specialist seller, and you can cope with the percieved embarassment, get some KY jelly down at Boots.
I guess you can tell the Boots assistant that you probably need two tubes to cover the entire length... 8)
DaveB
Re: CREAKY HARDTOP
Postby ektrolleyboy » Wed 29.04.2009, 13:28
Just don't ask if it will stop the squeaking! :lol:
ektrolleyboy
Re: CREAKY HARDTOP
Postby Bolsom » Wed 29.04.2009, 17:46
At my age it is as stated, creaking and not squeaking.
Thanks for the suggestions.
Colin
Bolsom
Re: CREAKY HARDTOP
Postby abmunro » Wed 29.04.2009, 20:47
Now we have two anagram poster's
The wheel restorer & ektrolleyboy
Here Welsh tree Rot & Beryl toolkey
abmunro
Re: CREAKY HARDTOP
Postby GeoffSmith » Thu 30.04.2009, 08:19
Watch out for Baron Mu. :-D
Re: CREAKY HARDTOP
Postby Jackonicko » Thu 30.04.2009, 11:44
It's the firm's fogey who worries me.
Jackonicko
Re: CREAKY HARDTOP
Postby Here Welsh Tree Rot » Thu 30.04.2009, 13:43
Mine creeked.
removed pillar caps.
Mine don't creek no more! :banana:
mae o'n siared trwy ei het.
Dwi a 'n fawr bloneg Cymraeg bastai bwytawr
Here Welsh Tree Rot
Re: CREAKY HARDTOP
Postby sucri » Mon 13.07.2009, 21:20
bonjour
can someone tell me where can i buy a hardtop for an elan M100
on this web site they tlak about the hard top made by Mr Simon Kurching
thank you
chris
sucri
Re: CREAKY HARDTOP
Postby MattDon » Mon 13.07.2009, 23:31
give these guys a bell. simon of SPC fame
MattDon
Re: CREAKY HARDTOP
Postby sucri » Tue 04.08.2009, 10:56
merci beaucoup mattdon
i will keep you informed
chris
sucri
