Sun visor
Sun visor
Postby geraldferreira » Sat 30.05.2009, 22:46
I have owned an SE turbo for about 3 years and in all this time the nearside visor has been floppy. Where it hinges inside the foam like material, it jusy seems too loose. I've tried sleeving the metal bars in order to increase the friction on the bars but this only last a couple of weeks and then goes floppy again. I think this may be damaged behond repair.
Does anyone know if replacements are available or has anyone found a fix for floppy visors.
Many thanks
Gerald
geraldferreira
Re: Sun visor
Postby tweetdriver63 » Sat 30.05.2009, 23:49
I took mine off and wrapped the pegs with black vinyl electrical tape. I only needed to do the driver's side, and it's been good for about a year. I'm about to re-do it because the tape has gradually worked its way out.
Some people just take them off and put them in a bin.
'91 Elan SE
'04 MB C230 Sport Coupe
'08 Mercury Mariner Hybrid
tweetdriver63
Re: Sun visor
Postby saska » Sun 31.05.2009, 15:03
tweetdriver63 wrote:I took mine off and wrapped the pegs with black vinyl electrical tape. I only needed to do the driver's side, and it's been good for about a year. I'm about to re-do it because the tape has gradually worked its way out.
I use heatshrink tube about 8mm diameter (its one of the standard sizes).
On the end to be inserted I leave a little extra and shrink it round the knob of the peg, then shrink the rest on tight.
Seems to work very well.
I certainly would on a track car but after nearly knocking down an old dear at a pelican crossing due to low winter sunlight, I've put them back on.
Tony
adw (at) saska.co.uk
saska
Re: Sun visor
Postby scottswatches » Tue 14.07.2009, 10:24
I have just bodged a fix, but it is working well. I have attached a small magnet i had kicking around to the visor that sticks to the roof clamp. I have just stuck it on with back tape for the time being, but it does stay in place and feels good. I got the magnets with a bath panel, so you would have to find your own solution to that question.
Scott.
Do I buy another Elan or go for something older and different?
scottswatches
Re: Sun visor
Postby tweetdriver63 » Tue 14.07.2009, 15:43
scottswatches wrote:I have just bodged a fix, but it is working well. I have attached a small magnet i had kicking around to the visor that sticks to the roof clamp. I have just stuck it on with back tape for the time being, but it does stay in place and feels good. I got the magnets with a bath panel, so you would have to find your own solution to that question.
I've never seen where anybody else used magnets. If they work well, then this type of product is available at most stores that sell craft supplies/office supplies/hardware. Normally it's used to make your own refridgerator magnets, like out of business cards, etc. Might work though.
'91 Elan SE
tweetdriver63
Re: Sun visor
Postby tweetdriver63 » Tue 14.07.2009, 18:42
After just driving my car, it occurs to me that magnets that stick the visor to the hood latches will only work when the hood is up. What do you do when you have it down??
'91 Elan SE
tweetdriver63
Re: Sun visor
Postby scottswatches » Wed 15.07.2009, 10:37
tweetdriver63 wrote:After just driving my car, it occurs to me that magnets that stick the visor to the hood latches will only work when the hood is up. What do you do when you have it down??
This is a very good point, and it shows that car alterations should not be carried out when it's raining! I might just take the useless visors off and keep them for the next owner!
Scott.
scottswatches
Re: Sun visor
Postby nicowalker1 » Thu 16.07.2009, 21:23
thats exactly what ive done, mine wernt loose though. I just needed the extra 1/2" view as im to tall for the car :?
nicowalker1
Re: Sun visor
Postby trig » Thu 16.07.2009, 21:47
I took mine off ad have not missed it so far..
trig
How to remove visors?
Postby tigerdog » Sat 18.07.2009, 19:07
Looks like I should just undo two screws and the visor will drop out. Unfortunately, the screws simply twirl without backing out. Any ideas on how to overcome this? What do they screw into?
Re: Sun visor
Postby RayD » Sat 18.07.2009, 20:26
Tigerdog,
When I had a similar problem with the over centre clips they were this type ...
Try levering it down at the same time as turning, failing that you’ll need to see if you can get to it from above.
Superglue may hold the nut sufficient to remove the screw.
