by Eggflipper » Sat 18.07.2009, 22:15
Has anyone replaced this cable? How does it connect to the release handle?
Eggflipper
by Specky » Sat 18.07.2009, 23:02
I've tried to removed one... new cable and handle on standby..
IIRC there was an issue with removing it...
Here's a few ways round the issue...
Undo the bonnet end of the cable completely...
Unbolt the black release handle...
extract the swaged end from the release handle...
If the conduit is good..Pull the wire all the way through and insert a new wire in the old conduit.
If you try to slide the white plastic housing rearwards it will most probably end in tears
De-rivet the full assembly, extract the whole thing and work it carefully on the bench
Hope that helps...
Ex
by Eggflipper » Sun 19.07.2009, 09:28
THANKS FOR THE REPLY,BUT UNFORTUNATELY THE BONNET END IS NOT ACCESSIBLE BECAUSE THE LATCH WILL NOT RELEASE THE HOOD. ANY OTHER IDEAS?
Eggflipper
by Specky » Sun 19.07.2009, 09:51
Can you let us know which car you have? Is it a LHD Fedral car, the type you get in the USA.
Or just the normal varient?
Can you say why the handle won't work? Has the cable snapped?Is it jammed solid?
by Eggflipper » Sun 19.07.2009, 22:15
SORRY, MY CAR IS 1991 ELAN. LHD.
Eggflipper
by Eggflipper » Sun 19.07.2009, 22:18
I DON'T THINK THE CABLE IS BROKEN. I THINK THE MECHANISM THAT HOLDS THE HOOD DOWN IS STUCK. WHEN I PULL THE HANDLE THE CABLE MOVES BUT DOES NOTHING TO RELEASE THE HOOD.
Eggflipper
by Specky » Sun 19.07.2009, 22:32
Eggflipper wrote:SORRY, MY CAR IS 1991 ELAN. LHD.
Are you in the USA?
I'm trying to work out which nose you have on the front of your car.
by whippit » Sun 19.07.2009, 22:43
get someone to press on the bonnet (hood) at the same time as you pull the handle,
it takes the pressure of the spring, also put the lights on so you can get your hand under the bonnet and pull at the same time.
whippit
by Eggflipper » Mon 20.07.2009, 08:40
WIPPET, I TRIED THAT, UNSUCCESSFULLY. WE TRIED PULLING IT AS WELL. NOTHING. THANKS FOR THE THOUGHT.
Eggflipper
by Eggflipper » Mon 20.07.2009, 08:41
I BELIEVE THE CAR IS THE USA VERSION.
Eggflipper
by Specky » Mon 20.07.2009, 19:20
Sadly I don't know how to get into the Fedral version as I'm not familiar the front end and structure...
Sorry fella
by whippit » Mon 20.07.2009, 23:31
the cable is clipped to the inner wing drivers side on the uk car, i guess its the same on the fed spec , take the wheel arch linner out , stick your hand up to the top of the inner wing, you should be able to find the cable, give it pull,
if the cable has come away at the latch, it will be a pain in the butt to sort ,
the only way i can think of is try and get your hand to the latch from the head light pod
i'm not able to get to my car at the moment to see if its do-able, sorry if its not much help
whippit
