A pillar seals,another alternative found!.
Postby Jamie N » Thu 17.06.2010, 23:22
And unlike my last discoveries back in 2007 (renault 19conv),these ones are much more easily found,on a mk1 MR2 t-bar,although i think the fixed roof model will be usable also.These were sourced in a scrapyard and i have a spare set also,i havn't checked new prices with toyota but a quick check on mr2 forum indicated they were easily available.
These are rubber seals very similar to the Renault ones i used on my blue Elan,not spongey rubbish that Lotus used :D ,and have a very smooth classy finish,the fit is actually very like the original,with the stepped part for the mirror and the flared end to attatch to the body,the rear channel is also a perfect fit.
The tricky part is finishing the top where it meets the hood,i cut it level with the screen then used a flat piece of the same type rubber and cut out the shape to fit,i then superglue gelled this in position and then sikaflexed it to the frame,after 10 mins i dabbed the sikaflex with a rag dipped in olive oil to flatten the sikaflex and blend it seamlessly into the seal,the end result being a fabulous improvement on the originals,perfectly waterproof as it meets beautifully with the glass and will still look new for many years,these seals are probably 20 years old already!.
Hopefully here is the pics,Jamie. :wink:
Monaco S2 #406
Jamie N
Seal God
Re: A pillar seals,another alternative found!.
Postby esprit888 » Thu 17.06.2010, 23:52
Did the Mr2 site show a part number?
DROMONG wrote:And unlike my last discoveries back in 2007 (renault 19conv),these ones are much more easily found,on a mk1 MR2 t-bar,although i think the fixed roof model will be usable also.These were sourced in a scrapyard and i have a spare set also,i havn't checked new prices with toyota but a quick check on mr2 forum indicated they were easily available.
esprit888
Postby RayD » Fri 18.06.2010, 08:02
Excellent job Jamie,
Postby tigerdog » Fri 18.06.2010, 10:17
Wow - those look like they belong there! So to be clear, these are from a 1st-gen Toyota MR2 (the little wedgy one) with removable top?
Postby Jamie N » Sat 19.06.2010, 12:54
tigerdog wrote:Wow - those look like they belong there! So to be clear, these are from a 1st-gen Toyota MR2 (the little wedgy one) with removable top?
I dont have a part number,and yes they are from the door wedge MR2,1986-1990 ish,usually easily identifiable by the voluminous amounts or iron oxide. :D
Monaco S2 #406
Jamie N
Seal God
Postby hatters » Wed 23.06.2010, 21:19
Nice job
They look much better than the originals . did you just pull the old ones off and did they come off OK how easy was it ? You have made a great job of them they look very proffesional well done
hatters
Postby muley » Thu 24.06.2010, 19:40
Jamie
Well done - good posting.
Another tip for sikaflex or black silicone is to put cling film over it then smooth it - it won't stick while it's wet or dry so you can close the door onto it while it goes off.
Postby mikesimmo » Tue 04.01.2011, 16:44
New to this forum and m100's, so sorry if i ask daft questions.
Read your post with interest, but unsure which seal you have replaced is it the A pillar seal that runs up the sides if the winscreen or accross the top ?
Sourcing Lotus parts is prooving very dificult
I have just bought an Elan and looking to replace hood and all seals, it leaky.
I live in East Yorkshire so if you have any recomendation
mikesimmo
mikesimmo
Postby rip » Thu 06.01.2011, 14:05
A post is at the front of the door window.
B post is the rear of the door window.
I thought Lotus had made a lot of these recently, enough to have them in stock for quite some time?
They were looking at an alternative material but apparently the covered foam gave the best seal :shock: so stuck with the original meterial.
Postby tomac1975 » Thu 06.01.2011, 15:00
Hi mikesimmo,
Paul Mattys and sj sportscars had the seals in stock recently.
Tom.
tomac1975
Postby mikesimmo » Sun 09.01.2011, 23:06
which sikaflex do you reccomend
mikesimmo
Postby theelanman » Mon 10.01.2011, 00:21
sikaflex 221
http://cgi.ebay.co.uk/Sikaflex-221-blac ... 1e6062780e
Sikaflex 221 *Black*
Sikaflex®-221 is a high-quality multi
purpose non-sag 1-c polyurethane
sealant that cures on exposure to
atmospheric humidity to form a
durable elastomer. For US: Meets
approvals ASTM C920 types and
Federal Specifications TT-S-
00230C. Sikaflex®-221 is
manufactured in accordance with
ISO 9001 / 14001, quality assurance
system and with the responsible
care program.
Product Benefits
- 1-C formulation
- Elastic
- Low odor
- Resistant to ageing and
weathering exposure
- Non-corrosive
- Can be overpainted
- Can be sanded
- Bonds well to a wide variety of
substrates
Postby garywbrooks » Sun 05.06.2011, 15:08
My A pillar seals were disintergrating at the top and water was getting in when it rained heavily.
I used Loctite Flexible Sealant and Clingfilm to stop it getting were I didn't want it. After a drying over night.. Well its not invisible mending! But I don't get a wet right knee anymore!
garywbrooks
