by theelanman » Fri 27.05.2011, 15:54
Ok.....so I got some shiney 3m number plates for the elan......
Last year on the Le Mans trip it was that hot and my rear green house was cookin the rear plate to the extent that it melted the sikaflex and warped the plate......ive now got round to sort this....my theory is upside down in the oven on a baking tray at about 75deg C...try and let it melt itself flat......anyone tried this?.....anyone any ideas about the melting point of perspex......
G
by GeoffSmith » Fri 27.05.2011, 16:38
Go for it Gareth - put something heavy on top to make sure it flattens. Did this with my works car pass and forgot about it. A few hours later is had changed from a curvy 3" x 2" piece of plastic to a perfectly flat one....... about 3cm x 2cm!
- Kitty Fiddler
by tigerdog » Fri 27.05.2011, 17:22
Sounds like it's worth a try. Instead of a baking plate, I'd think about using window glass (from a house, not a car!) It will provide a good flat surface. Maybe press the plate between two pieces with a brick on the top one. Start with a cold oven, heat then let cool to room temp before removing. I used this technique once or twice to take the warp out of old vinyl LPs.
by theelanman » Fri 27.05.2011, 17:26
What temps did you guys use?.......
Trying to avoid a sticky mess at the bottom of the oven.....oh and a bollocking......
by Gee0 » Sat 28.05.2011, 12:08
theelanman wrote:What temps did you guys use?.......
Just make sure that Mrs Elanman is out for the day, or you could get yourself into a heep full of trouble LOL
Gee0
by Neil D. » Sat 28.05.2011, 12:53
Glass Transition of PET is close to 80 C
85 C should do the trick
Neil
S2 # 541
Neil D.
by Songbird » Sat 28.05.2011, 15:23
How about putting it a flat tray with a weight, and then pouring boiling water over it.... or is 100c too hot ?
Songbird
