Boot panels have separated
Postby Faeview » Wed 30.04.2014, 11:41
The panels making up my boot have separated. Can someone suggest the best glue/adhesive to repair this
All natural...one of 129
Faeview
Re: Boot panels have separated
Postby Jeemy » Wed 30.04.2014, 12:15
I'd guess 2-part epoxy resin.
T: 0800 084 3084
M: 07391 295 146
Jeemy
Postby Brit-Car-Nut » Wed 30.04.2014, 12:39
Faeview wrote:The panels making up my boot have separated. Can someone suggest the best glue/adhesive to repair this
Exactly, which panels making up your boot? Unless something has cracked or broken, all of the major panelas are bonded with betaseal which is a urethane based, flexible adhesive similar to the stuff they glue windscreens into the cars.
Pictures or some detailed notes would be helpful since there are no small panels back there unless something has broken.
Postby Faeview » Sat 03.05.2014, 00:29
The top of the boot has delaminated from the main frame panel. Refer to the attached photos, sorry for quality of the pics.
Faeview
Postby Brit-Car-Nut » Sat 03.05.2014, 03:32
I am sure you can see the issue, but I am having trouble. Maybe a picture further away would help me get my bearings.
Can you point to the problem area in this picture?
Click on the picture to get a better view.
I have a lot of boot area pictures and can better advise on the correct repair method if I know what you are fixing.
Postby Faeview » Sun 04.05.2014, 12:03
My problem is not the boot itself but the boot lid. I have learnt so much from this forum and look forward to learning more as I struggle to get my NA m1000 back on the road.
Faeview
Postby HJ2 » Sun 04.05.2014, 12:41
Don't worry! LEC will get you back on the road for sure!
Postby superbad » Sun 04.05.2014, 23:29
My bonnet is doing the same thing- the frame underneath has separated from the upper panel in places. Whatever adhesive they used for panel bonding sucks. It also caused a reaction that swelled the fiberglass above and is visible in the paint (that might be why it's not bonding well too). I haven't addressed it yet, but I was planning on using something like this:
http://www.westsystem.com/ss/g-flex-epoxy/
Really any decent structural epoxy should be fine, but a little added flexibility is probably a good idea given the temperature cycling, opening and closing, etc.
superbad
Postby chrisP » Fri 09.05.2014, 12:58
There is a good choice of structural adhesives here: (great customer service as well)
http://www.easycomposites.co.uk/Categor ... sives.aspx
chrisP
