A post seal replacing
Postby david.bradley » Sat 13.09.2014, 21:08
Hi all
I've tried to follow all the posts around alternative rubber seals, but from what I've read I dont think there are any for sale.
I've just looked at my old ones and the centres are dry & crumbly - which cant be good
Paul Matty seems to list them at £70plus, plus VAT
I'd prefer rubber, but at the moment I just need to sort things out quickly.
What is involved in replacing the seals - both getting the old ones off/out and how the new ones are fixed in please
david.bradley
Re: A post seal replacing
Postby novacaine » Sun 14.09.2014, 01:08
They are fairly simple to fit, they just clip in at the top and then you just need to push the long edge in with the handle of a spoon and then a little sikaflex at the bottom.
Easy to pull off too, as long as you don't mind tearing them. All you may have to do is scrape out the old sikaflex
i managed to remove mind without damaging them. They were brand new when i bought the car, but i got my hands on some of Jamie's rubber a posts
novacaine
