New version of Intermediate Seals
Postby Jamie N » Sat 18.07.2015, 21:20
These were made recently but i have not had time to post them up. Completly new way of making them from the previous ones, these are as close to the originals as i can possibly get but made from EPDM Rubber. Instead of the "Nut in a blob of sealant" that the originals have for adjustment, i have used a plastic insert which has more travel, and more importantly wont rust solid and make them almost impossible to remove!, used with Stainless steel screws they can be fitted and removed quickly and easily. Although not visible the backing plates on them are also Stainless steel.
The upper seal is the original, although not in too bad condition its still Sponge, which is just nae use to Man or Beast. :D .
This one shows the side part of the Header seal with the original style of adjustment on the left, new idea on the right, these inserts are mounted into the Stainless backplates.
All the other seals removed for better pictures.
The ultimate aim for me is make it look fresh, modern and as tidy as possible , the better waterproofing is just an added bonus. :cheers:
Monaco S2 #406
Jamie N
Seal God
Re: New version of Intermediate Seals
Postby HJ2 » Sat 18.07.2015, 21:39
... You know my thoughts about these.... When can i place my order? :porn: :clap:
Postby CalElan » Sat 18.07.2015, 22:59
shall I start a list???
CalElan
Postby par » Sun 19.07.2015, 11:48
Having seen these seals first hand, these new type are of the highest quality and a huge improvement on the OEM parts which still seem to carry a premium when they come up on Ebay!
Just need to find something to distract Jamie long enough so I can swap the seals from Jamies car on to mine :wink:
par
Postby Steve A » Sun 19.07.2015, 18:00
:clap: The magician of rubber does it again :bowdown:
Postby lt0302 » Mon 20.07.2015, 06:07
I'm interested
91 Lotus Elan
01 Lotus Esprit
05 Lotus Elise
14 Lotus Evora S
lt0302
Postby Danevansgolf » Mon 20.07.2015, 17:09
I'd like a set aswell please. That's if your going to make a few sets.
Danevansgolf
Postby Megwenda » Fri 25.09.2015, 10:49
Me too
Megwenda
Postby Andy C » Sun 27.09.2015, 13:11
Start a list ... And add me to it please
Andrew
Medina Green #296 Brians Wilwood Brakes, Everest Chip, Piper 2.25, PWR Cooling & ProTech Suspension
Andy C
Postby HJ2 » Sun 27.09.2015, 13:12
1. HJ2
2.
