by markiep » Mon 12.06.2006, 11:57
can anyone recomend a good paint shop in the bristol area as i have a patch of blisters on my left front wing that ireally want sorted.the tale of their existence is somewhat sickening.car in my garage.shelves on left side, old can of nitromorse on shelf,nitromorse eats through can gradually runs down shelf bracket to bottom shelf,i think you can see where i'm going with this,i mean you couldn't make it up.the wisdom of leaving a can of paint stripper anywhere near my car is of course debatable but come on what are the chances.Anyway any advice about spraying a small area on an elan or agood paint shop with someone who know their stuff would be much appreciated.
it doesn't matter what temperature a room is it's always room temperature.steven wright (not to be confused with steve wright)
markiep
- Tinkerer
by johnbenk » Mon 12.06.2006, 16:34
Hi
Depends on "how much" the paint stripper has "eaten" into the Gel coat.
You will need a good body shop guy who is good at "filling in" with plastic filler. My advice would be to find a Classic Car restorer.
Painting is not the problem. Getting the wing to look right from different
angles could prove difficult. It may be possible to do a "fade out" repair.
Have you a photo of the damage??????? You need a product called
a "guide coat" used in the trade this will show any hollows or depressions
caused by the stripper after spraying with primer filler.
Is it at the top of the wing or has it run down all the way?
johnbenk on Thu 15.06.2006, 15:55, edited 1 time in total.
johnbenk
- The only Gay in the Village
by markiep » Tue 13.06.2006, 00:59
thanks for advice john will try & get picture up but will probably take a while,damage fairly localised & hasn't run,lots of little blisters maybe 30altogether in about a square foot.spoke to malmsbury specialist cars todaywho i use for servicing etc & they recomended someone they use so thought i'd let him have a look' just hope not to expensive,but it's got to be done!
markiep
- Tinkerer
by Ultimatt » Wed 14.06.2006, 17:17
Had my red elan completely resprayed recently by a small paint shop in Swindon. They did a fantastic job and went to high levels of detail. I would highly recommend them. They specialise in accident damage and the like so doing a smaller area should not be a problem. Not too sure about how accurate they can get on a colour match though. The chief there is very knowledgable about paint technology so might be worth a consult.
Let me know if you want contact details.
Matt
Ultimatt
by johnbenk » Wed 14.06.2006, 19:30
Hi
Paint matching not a problem today. DONT HAVE IT DONE IN WATERBASED PAINT. Go for "clear over base" as it is known in the trade.
Lechler make a good base coat. Try and get a "two pack Lacquer" finish.
A good paint supplier to the trade will supply you with a small half litre of "base coat" ready mixed to match your colour coding.
You need to be in the trade to buy "Two Pack Lacquer " though as it has to be sprayed with an AIR FED MASK.
You can do a fade out repair with base coat but need to clear lacquer the whole wing.
It is the scotching off of the panel that cost the money. You should be looking at about £100 for the wing, but blisters may be more as some filling would be needed.
Labour is the main cost. The paint should only cost you about £10.
johnbenk
by clemo » Thu 15.06.2006, 22:36
lechler is not a great match for lotus dupont equal in red., however standox is pretty damn close and with tint its spot on...
as for nitromores , damn thats evil..
i know sw lotus gets his cars painted in torquay ,but havent managed to find out exactly where..
will keep hunting ..
clemo
- LEC Administrator
- Location: TORQUAY Devon. Cream first then Jam obviously.
by Monty » Thu 15.06.2006, 23:11
Ultimatt wrote:Had my red Elan completely resprayed recently by a small paint shop in Swindon. They did a fantastic job and went to high levels of detail. I would highly recommend them. They specialise in accident damage and the like so doing a smaller area should not be a problem. Not too sure about how accurate they can get on a colour match though. The chief there is very knowledgable about paint technology so might be worth a consult.
Matt
When are we getting the pic`s of this paint work
- Chunder King!
by Ultimatt » Thu 15.06.2006, 23:23
I'm working on it Monty. I'm working on it.
Problem is... as soon as I see this bright sunshine and lovely weather... I get in the car and drive it rather than taking pretty pictures.
Tell you what... Once I've washed it at the weekend, I'll take a few snaps of it. I have a few finishing touches to do like wheel centres and a custom designed Lotus Elan logo I've designed for the wheel spokes, but I'll get you some more pics when that phase is complete
The paint and look of the car are dramatically different when it is overcast and when the sun is out. The paint is the lightest red metallic on the market and has a gold fleck in it which glistens in the sunlight. Don't know if I'll be able to do it justice on film but I'll give it a go.
Matt
Ultimatt
by markiep » Fri 16.06.2006, 16:41
thanks for info everyone
You guys really know your stuff! may try your guy in swindon ultimatt i'll pm you if i need details but think i'm going to try avon coachwork in timsbury first,they're in club lotus directory & pretty close to me.Anyone got any experience of them let me know.Only saving grace is the cars white so doesn't look to bad. cheers mark.
markiep
- Tinkerer
by Paul.P » Fri 16.06.2006, 20:42
Hope she comes out ok Mark, glad it wasn't the cat peeing then ?
by Paul.P » Fri 16.06.2006, 20:43
by markiep » Fri 16.06.2006, 21:30
feel a bit guilty now what with having her put down.That's the problem with capital punishment.
markiep
- Tinkerer
by Paul.P » Fri 16.06.2006, 21:51
markiep wrote:feel a bit guilty now what with having her put down.That's the problem with capital punishment.
, good job it wern't the wife then !
by markiep » Fri 16.06.2006, 22:00
i need someone to look after the kids.& i'd have to get a proper job.
markiep
- Tinkerer
by Ultimatt » Mon 19.06.2006, 20:08
Ultimatt
