3D Printable Wire Bending Jig for fuel injector clips
Postby SomeoneTakeTheWheel » Mon 12.10.2026, 19:20
In replacing my fuel injectors, I didn't like the condition of some of the little wire clips that lock the electrical connector on. I decided to make my own, but they are a very specific shape. So I designed a jig that would let you bend and trim 0.9mm spring steel wire into the exact shape needed.
I recommend printing in PETG or ABS or stronger. I printed in PLA and the strength of the steel wore that jig out after 2 uses.
https://www.thingiverse.com/thing:7421531
SomeoneTakeTheWheel
Re: 3D Printable Wire Bending Jig for fuel injector clips
Postby DublinBlueElan » Tue 13.10.2026, 16:39
Interesting, do you have any other 3D prints relating to our cars?
1992 Aqua Blue se turbo
DublinBlueElan
Postby SomeoneTakeTheWheel » Thu 22.10.2026, 21:49
DublinBlueElan wrote:Interesting, do you have any other 3D prints relating to our cars?
Only a couple hub-centering rings for aftermarket wheels. But if I create anything new, I will let you all know.
SomeoneTakeTheWheel
Postby Fredjohn » Fri 23.10.2026, 16:49
Could you download the 3d file for this tool into the forum? There is a section in Manuals for 3d files. I could do it but I don't want to presume!
Thanks for your work and help in keeping our Elans on the road!
