Elanchips
Re: Elanchips
Postby V8vroom » Fri 26.08.2016, 19:55
I think we all agree - and as you know I have a Piper exhaust plus chip and the boost creep occurred before the chip was put on.....
it's just a little odd that Mark at Kelvedon wasn't aware of the need for wastegate porting......Top Bloke though :D
R
Lotus Elan S2 No. 513 Norfolk Mustard
V8vroom
Re: Elanchips
Postby simonbuk » Thu 01.09.2016, 16:36
So if I don't currently appear to have boost creep ( haven't taken it up to the redline yet but must have been over 5000+, with a 2 1/4 inch exhaust, KnN filter but nothing else. Should I expect to get boost creep when I put a new Elan chip in ?
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: Elanchips
Postby John_W » Thu 01.09.2016, 22:19
Simon,
Boost creep has nothing to do with what chip you have in the car. It has to do with the physical set-up of inlet and outlet, atmospheric conditions, and how long you have the pedal on the right stuck into the carpet.
Re: Elanchips
Postby Elannewbie » Fri 02.09.2016, 15:22
Does anyone know how to get hold of mr mountain chip man?
I registered on his website and emailed him about a month ago - no reply.
No current stock of chips showing on the website.
Does anyone know if he uses this forum?
Black S2 #073 "it's only metal - it cannot win!"
Elannewbie
Re: Elanchips
Postby simonbuk » Fri 02.09.2016, 15:29
He has only recently come back from holiday so might be catching up on things.....
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: Elanchips
Postby V8vroom » Mon 20.02.2017, 14:40
Hi guys - I'm stuck....
As you know I've issues with the Turbo suddenly being held back at around 5000rpm 75% of the time under full throttle esp if I've just used 2nd gear and changed up into 3rd under full throttle....initially I thought is was the sticking wastegate actuator.
the guys at Kelvedon Lotus couldn't find anything and Mark there has said he was not aware of this problem in Elan M100s....???
My local independent garage has suggested I need to see a 'specialist' and recommended ITS Turbos in Darlington????
This is obviously a long way away from Peterborough.....
I have done the 'Wastegate Wiggle' which helped a little... can anyone here recommend somewhere where they've actually had their Turbo bored up / ported? Would anyone here be willing to do it for me for a fair fee??
I'm getting frustrated now as sadly its spoiling my use of what is otherwise a lovely little car :(
If you've had your wastegate bored up / ported please let me know if this made any difference to your ECU cut-outs.... I really need your help now guys :)
As you may be aware it has an aftermarket Piper exhaust.
thanks as ever
Rupert, Stamford.
V8vroom
Re: Elanchips
Postby Artaban » Mon 20.02.2017, 15:04
Can you just confirm that you are getting fuel cut off, i.e. the engine light comes on for about 15 seconds and theres no power until it goes out again?
Artaban
Re: Elanchips
Postby V8vroom » Mon 20.02.2017, 15:21
thanks Artaban...
I have only seen the light once.... it doesn't appear otherwise.... and 'rev block' lasts around 5 seconds (which seems an age when trying to accelerate!)
thank you
V8vroom
Re: Elanchips
Postby V8vroom » Mon 20.02.2017, 19:56
Update
Dear Artiban...
Good drive home, traffic quiet by 6pm!
Just to confirm.... no engine light comes on.... sometimes all is fine and it revs freely... other times and its like Ive hit a rev limiter but at only 4500 rpm..... it can be any gear.... any time.... the only thing constant is its with full or near full throttle
I did try fuel injector cleaner last year which helped a little... maybe I need to buy some more....??
R
V8vroom
Re: Elanchips
Postby steve matthews » Tue 21.02.2017, 00:48
Does it do it in the damp weather more than the dry weather?
Steve
steve matthews
Re: Elanchips
Postby Elanlover » Tue 21.02.2017, 05:18
Not looking over all the details on this (out of town at the moment) but you might want to check your throttle cable for play. Mine had a fair bit of play and I couldn't get "true" full throttle with the pedal to the floor. Consequently, the turbo was maxing out around 5 bar if I recall. Tightening the cable solved it.
Re: Elanchips
Postby Fredjohn » Tue 21.02.2017, 06:34
Elanlover wrote:Consequently, the turbo was maxing out around 5 bar if I recall. Tightening the cable solved it.
WOW! I know you're good at doing upgrades, but 5 bar!!! :burnout:
How did you get that? :D :D :D
Re: Elanchips
Postby V8vroom » Tue 21.02.2017, 09:15
Full throttle does work 50% of time..... its the other 50% thats a problem :(
In terms of damp weather - it's usually better warmer weather I think (from memory as its been a while!!)
thanks
Rupert
V8vroom
Re: Elanchips
Postby steve matthews » Tue 21.02.2017, 13:31
Warmer weather less dense air. Cold moist air more dense and creates overboost if it is allowed to.
Steve
steve matthews
Re: Elanchips
Postby HJ2 » Tue 21.02.2017, 13:39
Overboost... Yes I think so as well, but then no engine check light.. ?
Are you sure that you have gapped the spark plugs correct?
Re: Elanchips
Postby Artaban » Tue 21.02.2017, 15:30
My money is on a combination of two problems; boost creep and sticking wastegate. Porting the wastegate might not solve it but it will be one less factor to consider and freeing up the sticking wastegate with Phil's excellent method (viewtopic.php?f=31&t=25846#p327471) can only help as well.
Additionally if the spark plugs haven't been replaced for a while it can do no harm to put new ones in and just check that each plug is getting a spark to rule out the HT leads.
I think you are going to have to rule out the most obvious before you move onto the obscure. At least you should be able to find a little engineering company or garage that will port the wastegate for you locally. I can't see the need to travel miles to a specialist turbo shop.
Keep us up to date as you begin to rule out various things.
Andy
Artaban
Re: Elanchips
Postby V8vroom » Tue 21.02.2017, 21:05
Ok thanks guys
As I said I've done the wastegate wiggle...
Will change spark plugs too
Will ring a few garages to port wastegate ....
V8vroom
Re: Elanchips
Postby alan e » Tue 21.02.2017, 22:08
Porting the wastegate is easy getting the turbo off is the hard bit, if you do take the turbo off its worth getting a stainless steel fixing kit to replace the fixing bolts.
2010 black evora
Austin 7 1932 box saloon
MG ZS EV
alan e
Re: Elanchips
Postby V8vroom » Wed 22.02.2017, 11:32
I am no mechanic sadly... the hard bit is finding someone near Peterborough who knows what you guys are all talking about and is willing to do the work!!!
So..... any volunteers!!!! :bonk:
V8vroom
Re: Elanchips
Postby HJ2 » Wed 22.02.2017, 12:52
Sorry, I don't intend to move to Peterborough :lol:
