'Off The Shelf' Induction Kit
Re: 'Off The Shelf' Induction Kit
Postby Sy V » Sat 12.03.2005, 09:38
Brian<br><br>How about all upper case?
Postby rob » Sat 12.03.2005, 10:32
There's no pleasing some people  ::)
rob
Postby Sy V » Sat 12.03.2005, 10:54
Just suggesting options dear Brookesy!<br><br> ::)
Postby F1 LOTUS » Sat 12.03.2005, 17:57
[quote author=Sy link=board=boost;num=1107808456;start=15#20 date=03/12/05 at 00:38:27]Brian<br><br>How about all upper case?[/quote]<br><br>I did this quickly and the upper case spacing didn't look right, in fact the italic as shown looked much better? I'll post an upper case snap after I've spaced the letters individually...
F1 LOTUS
Postby Darren » Sat 12.03.2005, 19:01
[quote author=Brian_MDB link=board=boost;num=1107808456;start=15#16 date=03/11/05 at 11:17:28]<br><br>Is there a stock hose size for plumbing back the BOV, if so it may be worth making a custom one of these to work with the Lid?<br>[/quote]<br>I think it's fair to say that 25mm is the most popular diameter used in Elan circles & that's the diameter of my IC pipe dump valve take off.<br><br>BTW, like the design.<br><br>Darren<br>~~~~~
Open mouth, insert foot.
Darren
Postby F1 LOTUS » Sat 12.03.2005, 19:11
[quote author=Sy link=board=boost;num=1107808456;start=15#20 date=03/12/05 at 00:38:27]Brian<br><br>How about all upper case?[/quote]<br><br>Here's an upper case version, I found a better font but the 'O' still needs spacing betterer...<br>Overall it looks neat but I think I prefer the slightly more dynamic look of the italic version?<br>Image
F1 LOTUS
Postby Nige » Sun 13.03.2005, 22:36
Very nice Brian.  Agree with you on the spacing of the O but my preference is the capitals.  Lid alone is good would love to go the whole hog though.<br><br>Nige
Back in Blighty
Nige
Postby F1 LOTUS » Sun 13.03.2005, 23:15
It seems like there could be enough interest to make this viable, the mold tool cost will make or break it however and dictate how complex the design can be. What I've modelled here is about as simple as it gets from a tooling standpoint.<br>I'll get an estimate for mold tool cost ($300-$400?).<br>Part cost I would guess to be around $120?<br>If somebody would like to set up a poll then we can get some idea how the cost may be spread?
F1 LOTUS
Postby Matt RI » Thu 17.03.2005, 22:36
[quote author=elanman link=board=boost;num=1107808456;start=0#14 date=03/11/05 at 02:05:39]I would be very interested in a CF replacement for the trash can.  Firstly, it's functional, secondly, it would facilitate plumbing in the recirculating dump valve neatly, thirdly, it would match the Carbon IC pipes I have on order from Darren, and finally it would look great (anti bling pill required here).  It will have a price but quality always does.<br><br>Nige[/quote]<br><br>I have not been able to say "no" to a nice piece of carbon fiber yet, don't know why I would stop now...  Besides, it looks so pretty...<br><br>Nitroman has a point about asking for too much and receiving nothing in return, but along with Nige, I would be pretty psyched if the whole induction unit (can, lid paired with Darren's pipes) with a place to plumb the BOV is an option for purchase.<br><br>Then again, I have added nothing to this forum except a sneaky "sure, I'll jump in and benefit from all your work!" so my opinion is only worth so much...
I like traffic lights. But only when they're green...
Matt RI
Postby Darren » Mon 21.03.2005, 22:41
I've been giving this whole recirculating back into the airbox some serious thought and whilst it makes perfect sense to do so, it's either going to be expensive or a bit of a botch job.<br><br>So I go to think why am I bothering? <br><br>Ok back to school, we know that none recirculating valves are noisey & we know that there's a risk of dirty air entering the IC 'circuit' when the valve moves from open to closed.<br><br>So given the above, I went looking for an alternative 'solution'. After a fair amount of messing around, I came back with the following, now it's not been tested yet & the joining between the IC pipe and the valve is only for show but I think it may just work.<br><br>Here's my 'solution' a 50mm diameter breather airfilter, with a 25mm 'rubber' connector (it even comes with a hose clip). The filter is washable rather like a K&N and what's more, it costs around £10 inc UK postage.<br><br>Image<br><br>&<br><br>Image<br><br>So fitted to my Carbon top IC pipe & my Stratmosphere recirculating dump valve, it looks a little like this:-<br><br>Image<br><br>Now from my thinking, the filter should help to 'reduce' the sound or be it less than the main airbox & the fact that it's a filter, it should stop any crap being sucked into the system. Owwww & lets not forget the fact that it only costs £10, inc hose clip & UK delivery.<br><br>Any thoughts, observations ?<br><br>Darren<br>~~~~~<br>
Darren
Postby Monty » Mon 21.03.2005, 23:44
I`ve been thinking of this, as i may be fitting on open airfilter,  sounds good to me, let me know when u test it  ;)
Postby F1 LOTUS » Mon 21.03.2005, 23:45
For sure filtering any air that may get back in is prudent but I don't think it's going to quieten things much...when I replaced the stock paper filter with a drop-in K&N filter the turbo 'stuttering' noise became more noticeable :-/<br>It shouldn't be too difficult to come up with a silencer design...I seem to recall high-speed airtools having a silencer that was basically an open 'concertina' type rubber hose?
F1 LOTUS
Postby Monty » Tue 22.03.2005, 19:03
I was thinking of a 6" 25mm rubber pipe with holes drilled through at one end and a piece of foam rammed in and the end caped off.  :-/
Postby ESM » Tue 22.03.2005, 22:02
ESM
Postby Monty » Tue 22.03.2005, 22:10
Thats interesting, wonder if they`ll ship to uk  ;D and it`s cheap  ;)
Postby F1 LOTUS » Wed 23.03.2005, 01:46
[quote author=ElanScanMan link=board=boost;num=1107808456;start=30#33 date=03/22/05 at 13:02:51]How about the real deal? http://www.2linc.com/air_tools_silencer.htm[/quote]<br><br>After I posted my message I found the exact same link, this would be simple to make but I've no idea how effective this would be?
F1 LOTUS
Postby F1 LOTUS » Wed 23.03.2005, 01:49
One of these would be perfect...<br>http://www.carlsoncalls.com/volo.html<br>
F1 LOTUS
Postby Nige » Wed 23.03.2005, 10:06
Brian, you must be Quackers  ;)!<br><br>Nige
Back in Blighty
Nige
Postby Monty » Wed 23.03.2005, 20:45
[quote author=ElanScanMan link=board=boost;num=1107808456;start=30#33 date=03/22/05 at 13:02:51]How about the real deal? http://www.2linc.com/air_tools_silencer.htm[/quote]<br><br>Thinking of ordering one of those silencers Alan has posted, but there`s a minimum of $25 dollars with out postage, so i need to order 3, so whos the 2 unlucky ones who`ll jump in with me? Will be less than £10 each<br><br>Product Id   Product Name/Description      Qty      Price<br>10032      No Clog Air Silencer 3/8 NPT      3      $10.68/ea      <br>SUBTOTAL      $32.04<br><br>SHIPPING METHOD      <br>UPS Blue - 2 Day Delivery<br><br>SHIPPING for UPS Blue      $15.50<br>TOTAL      $47.54<br><br>The site doesn`t seem secure, no padlock  :-/ <br>But says:-<br>When clicking the Submit Order button you will notice a picture of a small lock appear in the bottom portion of the browser window. <br>  <br>This lock certifies that your transactions from 2Linc.com are indeed secured by Verisign™ and encrypted with the latest SSL technology.<br><br>Is this sounding Dodgy  ???
Postby F1 LOTUS » Wed 23.03.2005, 21:17
You should be able to source something similar in the UK?
F1 LOTUS
