LGM/Ekapol Intake Pipes
Postby Ekapol » Tue 12.08.2008, 17:08
Few more payments coming in. Anybody heard from White91elan lately? :-)
BOV run # 3
1)White91elan : Samco black fittings,adaptor, re-route, and Greddy BOV Invoice sent
2)MattDon : Samco red fittings,adaptor, re-route, and Greddy BOV PAID
3)rip : Samco blue fittings,adaptor, re-route, and Greddy BOV PAID
4) Dave Ellis Samco black fittings,adaptor, re-route, and Greddy BOV Marie will contact Dave
5) techlectic : Samco black fittings, adapter, re-route, and Greddy BOV On the way - mailing
6) Richard K : Samco black fittings, adapter, re-route, and Greddy BOV PAID
7) theelanman : Samco BRG (or red) fittings,adaptor, re-route, and Greddy BOV PAID
Turbo intake pipe
1-Dico- Blue - Turbo upgrade PAID
2-Paul.P-Black + turbo upgrade PAID
3-Rogerf-Red PAID
4- Woody-Black. PAID
5. Ailwyn (Black) - Turbo upgrade Invoice sent]
6. MattRI- green or yellow (black if nothing else!) - turbo upgrade PAID
7. Dunnlor (Black) PAID
8. rip- Blue PAID
9. ab2cv - Blue PAID
10. Ailwyn (Black) - Turbo upgrade Invoice sent
11. Drassicjazz- Blue PAID
12. Richard K ( Black) - Turbo Upgrade PAID
13. davidjt (Blue) PAID
14. techlectic - Black On the way - mailing
15. theelanman - BRG (or red) PAID
Ekapol
Postby abmunro » Sat 16.08.2008, 21:29
Had my car on a rolling road.
It only made 166 BHP.
I have the BBR kit on which should make it 205 BHP.
The problem is that since fitting the LGM intake pipe I have found I have a leak.
I am going to look into getting better clamps than Jubilee clips.
I had the same problem with my GTiR when I raised the boost to 1.4 bar. It kept blowing the pipes off my intercooler.
I think it might be a good idea for the guys who are fitting LGM turbo upgrade too.
I am thinking of going for MIKALOR or SUPRA clips or similar.
Anyone else any thoughts.
Tony
abmunro
Postby nitroman » Sun 17.08.2008, 00:40
abmunro wrote:Had my car on a rolling road.
Tony
Abmunro, although I am a sucker for upgrades, standard "jubilee" (what a festive name for hose clamps!) clips tightened sufficiently should hold in the boost. You'd be amazed the number of boost leaks I cured by tightening all the clamps on a twin-turbo Maserati.
That said, if your jubilee has gone rust or bust, it's time to throw money at it!
nitroman
Postby lotusgirlmarie » Sun 17.08.2008, 07:56
Make sure you adjust the BOV as well. They are set with a fairly low activation preasure.
lotusgirlmarie
Goddess
Postby abmunro » Sun 17.08.2008, 08:34
I have tried to tighten them to no avail.
Will have a look at BOV.
abmunro
Postby lotusgirlmarie » Tue 19.08.2008, 01:15
just a quick update. All BOV's aquired. All piping for the last of the standard turbo's also aquired. Will try to get them cut and polished in the next few days.
lotusgirlmarie
Goddess
Postby abmunro » Tue 19.08.2008, 07:05
Hello Marie
Could you give me all the pipe diameter's so I can order some Mikalor's to replace Jubilee clips.
I am offshore so can't measure them
Tony
abmunro
Postby rip » Tue 19.08.2008, 08:02
lotusgirlmarie wrote:just a quick update. All BOV's aquired. All piping for the last of the standard turbo's also aquired. Will try to get them cut and polished in the next few days.
:smt023
Postby Ekapol » Tue 19.08.2008, 09:35
Ekapol wrote:
BOV run # 3
5) techlectic : Samco black fittings, adapter, re-route, and Greddy BOV PAID
Turbo intake pipe
3-Rogerf-Red PAID
8. rip- Blue PAID
14. techlectic - Black PAID
Latest update: I'll give it until the end of tomorrow for White91Elan to contact me, then the BOV will go to the next taker, since it's been a little while now.
Please let me know also if you hear from Ailwyn lately, or if you could help contacting him. Thank you.
Ekapol
Postby theelanman » Tue 19.08.2008, 11:11
I can ring him for you...or drop him a text....
hows that
cheers
G
Re: LGM/Ekapol Intake Pipes
Postby techlectic » Wed 27.08.2008, 00:48
Just a reminder of a request I made some time ago for unpolished pipes, so I can have them painted or anodized black. No problem if the work has been done already.
thanks
techlectic
Postby Nige » Thu 28.08.2008, 22:40
Ekapol, not sure who else is in the queue if white 91 can't be found but without wishing to jump ahead of anyone I'd be interested if there is a spare available.
Back in Blighty
Nige
Postby ailwyn » Fri 29.08.2008, 08:03
I've now fitted and tested the BOV, wound up the nut about 1.5 turns, doesn't leak at all under boost, but I do get blow off even at low throttle levels when I back off... should I be tightening any more or is this an expected behaviour.
Ailwyn
Postby Nige » Fri 29.08.2008, 10:58
ailwyn wrote:I've now fitted and tested the BOV, wound up the nut about 1.5 turns, doesn't leak at all under boost, but I do get blow off even at low throttle levels when I back off... should I be tightening any more or is this an expected behaviour.
Ailwyn
Sounds perfectly normal to me. I think the rise in pressure in the intake as you close the throttle even at low levels is enough to cause the dumpvalve to operate. I have not recirculated my current dump valve since I changed my airbox earlier this year and because I can now hear the dump valve it is clear it operates under all conditions.
Back in Blighty
Nige
Postby Rogerf » Fri 12.09.2008, 21:50
Just going slightly off topic.But i received a tax duty bill of £48 via DHL today for the BOV and pipe received a few months back.Has anyone else in the group buy received the same?
Getting a bit worried now as to how much the Duty will be on the Turbo Intake pipe due to be despatched shortly :shock:
Is there a way we can avoid so much Duty,perhaps recording less value or a gift on customes forms?
It just seems such a shame when the likes of LGM ,Ekapol etc put so much time and effort into group buys only for customes to take a large slice of it!!
Rant over,
Roger
Rogerf
Postby drasicjazz » Sat 13.09.2008, 07:29
i had to pay 82 euro duty/import tax on the Bov
i told Ekapol about it and next they will mark it as ''gift''
and hopefully use the noraml post service
not DHL or any other delivery companie
also the fact that they marked as BOV ....witch means 'carparts' increased the tax by a craesy amount
drasicjazz
Postby nitroman » Sat 13.09.2008, 07:36
drasicjazz wrote:i had to pay 82 euro duty/import tax on the Bov
INFECTIOUS DISEASE SPECIMAN
Fragile - DO NOT drop!
What's the tax on that?
nitroman
Postby Enright » Mon 22.09.2008, 22:50
Rogerf wrote:Just going slightly off topic.But i received a tax duty bill of £48 via DHL today for the BOV and pipe received a few months back.Has anyone else in the group buy received the same?
Rant over,
Roger
I've just received something similar.
I thought it was for something that someone had posted to me by accident, because it said on it "blow off valve and hoses", but I never bought a BOV. So they're trying to charge me for duty on something that I never actually had! :evil:
Postby Foo » Tue 23.09.2008, 13:52
Visit from the feds I would wager :D
Foo
Postby theelanman » Sat 27.09.2008, 12:02
any news?
just wondered if there were any updates???.......
