Intake Plenum Pipe Grommet
Postby Gareth » Thu 30.09.2010, 10:32
I think that's what I'm looking for!
Anyway, it's the rubber grommet surrounding a pipe (where it runs from the engine bay into the wheel arch) that runs from the top of the engine passing through
the engine bay in to the wheel arch.
Mine's perished!
Any info/help on where to obtain/purchase this appreciated
:D
Gareth
Gareth
Re: Intake Plenum Pipe Grommet
Postby Sy V » Thu 30.09.2010, 10:40
GROMMET, AIR PIPE tho INNER WING
SJ100L0001 EACH £7.95
SJ Sportscars
Postby Gareth » Thu 30.09.2010, 11:29
Thanks Sy, I'll contact them straight away!
:D
Gareth
Gareth
Postby tigerdog » Thu 30.09.2010, 17:55
The SJ part is not an exact match and requires a bit of fettling before it sits neatly in place. It is, however, MUCH better than a ratty, torn original.
Need picture and dimensions of original
Postby tigerdog » Thu 30.09.2010, 18:06
Been doing a bit of searching and came up with this (clicky) :
It fits my memory of what the original looked like but I no longer have mine to compare. What do you think?
Postby maz_r » Thu 30.09.2010, 19:58
Interesting....
So if there are 10 in a pack, and $14 a pack.....
You wouldn't get some and drop one in the post, would you Doug???? You'd still have 9 left (that you don't need!) :D
Martin.
maz_r
Binary Bodger
Postby Sy V » Thu 30.09.2010, 20:03
You see, only a pseudo-brummie would be so quick and unsubtle on the uptake. :wink:
Can I have one too please?
Postby GeoffSmith » Thu 30.09.2010, 20:07
Sits back on fat arse and struggles to raise a finger........
GROUP BUY! Count me in! :banana:
Seriously, we can probably find a UK source if Doug and I get our heads together.
Postby Sy V » Thu 30.09.2010, 20:28
Make it so, Smithers!
Postby Denny » Fri 01.10.2010, 07:27
I'm in for one of these as mine has also split :banana:
Denny
Postby ashm » Fri 01.10.2010, 10:10
I'll take one! :)
Adam
ashm
Postby Steve A » Fri 01.10.2010, 10:31
:D Yes Please :poke:
Postby hodge » Fri 01.10.2010, 10:58
Mine perished also so. . . me too please! :D
hodge
Postby Dave Eds » Fri 01.10.2010, 11:18
I'll start the list for you then Geoff!
1. Gareth
2. maz_r
3. Sy V
4. there's only on f in Geof Smith
5. Denny
6. ashm
7. Steve A
8. hodge
9. Dave Eds
Intake Plenum Grommet
Postby Gareth » Fri 01.10.2010, 12:13
tigerdog wrote:Been doing a bit of searching and came up with this (clicky) :
Thanks for the information.
I did "clicky" unfortunately after registering/ordering etc with them when I tried to pay and entered the UK as the sipping destination the shipment was refused due to (from memory) "prohibited export/import"
Never mind, I'll keep trying this side of the pond!
:shock:
Gareth
Gareth
Re: Intake Plenum Grommet
Postby DaveB » Fri 01.10.2010, 13:31
Gareth wrote:...the UK as the sipping destination...
Don't really know why... but it made me laugh :beer:
DaveB
Postby GeoffSmith » Fri 01.10.2010, 13:32
Me too! WSOH
Postby tigerdog » Fri 01.10.2010, 13:35
Hey, I haven't even seen one of these in person. I was just looking for someone who has an original, to see if this looks similar. Anyone got dimensions for clam-hole and boost-pipe? Can someone photograph the original to see if we have a match? The grommet itself appears to be made for mounting truck tail lights.
I knew I shouldn't have had the words "group buy" tattooed on me back.
Postby Dave Eds » Fri 01.10.2010, 13:49
have a search on here, I'm sure the Esprit has this part on the fuel tank filler neck!
Postby dapinky » Sat 02.10.2010, 09:38
can i have the last of the 10-pack :-D
1. Gareth
2. maz_r
3. Sy V
5. Denny
6. ashm
7. Steve A
8. hodge
9. Dave Eds
10. pinky
