by Lotus54 » Sat 08.10.2011, 01:07
My car came with an older HKS BOV. I noticed the lock nut was loose and perhaps the adjustment rod moved.
I also noticed the boost didn't seem to go oever around .8 bar (was .95). Could be something else (the car is new to me and I'm gradually working the bugs out of it), but I should get it set correctly anyway.
I couldn't find anything on the older ones online, and one know?
Tanks,
Mark
1978 Benelli 750 sei, 1972 Benelli 175 Enduro, 2018 Beta Xtrainer 300
Lotus54
by rip » Sat 08.10.2011, 01:33
I've got a Greddy BOV on mine with one of LotusGirlMarie's induction kits. I played around with the adjustment at first but I must admit that I could not tell the blindest bit of difference
A BOV should really release pressure when it detects a pressure difference across the throttle plate, so adustment should not be ass critical as for a dump valve?
Hopefully someone will put me in my place if I am wrong?
rip on Sat 08.10.2011, 18:52, edited 1 time in total.
by steve matthews » Sat 08.10.2011, 15:05
What I did.
Warm engine
open throttle by hand 1/4
Bov should vent upon throttle body closing
open throttle by hand 1/2
open throttle by hand 3/4
open throttle by hand full
If at anytime you see or hear bov opening upon opening the throttle by hand
tension up the Bov.
Also a Dyno will tell you if it is set correctly.
Just my 2 cents
Steve
steve matthews
