turbo shield
turbo shield
Postby smudge » Thu 15.03.2012, 17:03
Help been stuggling trying to remove the turbo shield :twisted: the bolt down the left side is being a bugger, I've tried rapid ease for the last three days no luck, any suggestions would be welcomed,
Smudge
smudge
Re: turbo shield
Postby GeoffSmith » Thu 15.03.2012, 20:20
I had exactly the same problem (not any more thanks to deeaitch's stainless kit) and managed while lying under the car with a flat ratchet spanner wedged in place with a sledgehammer shaft. Good luck!
Re: turbo shield
Postby smudge » Fri 16.03.2012, 07:30
thanks Geoff,
I'll give it a go,
smudge
smudge
Re: turbo shield
Postby muley » Fri 16.03.2012, 08:24
..don't be surprised if it shears off! Mine did.
Good luck
Re: turbo shield
Postby Gary1958 » Mon 19.03.2012, 16:42
I also tried to undo these nuts yesterday and failed. Left them soaking in "Shock and un-lock" to try again this weekend
Also, with the Wastegate wiggle am I trying to turn the rod using my long nosed pliers say from 12.00 to 3pm (as in, move the pliers from the engine to the bumper)or move the rod from right to left etc?
Sorry, if its a numpty question!
Gary1958
Re: turbo shield
Postby HJ2 » Mon 19.03.2012, 17:28
Hi Gary,
For a succesfull wiggle you'll have to move the 'needle' axial! Turning will not do anything.
You could try to undo the nut when the turbo is still hot, but make sure to wear proper heatresisting gloves! (not the ones in your kitchen mind you... :poke: )
Re: turbo shield
Postby Rice crispy » Mon 19.03.2012, 22:07
Gary left to right :D
Rice crispy
Re: turbo shield
Postby HJ2 » Mon 19.03.2012, 22:45
Is that his last name for real?! :clap:
Re: turbo shield
Postby Rice crispy » Mon 19.03.2012, 23:42
Sorry lost me who's last name?
Rice crispy
Re: turbo shield
Postby HJ2 » Tue 20.03.2012, 09:37
Left to right :o :lol: :lol: :lol:
Re: turbo shield
Postby Rice crispy » Tue 20.03.2012, 10:00
:lol: ok
Rice crispy
Re: turbo shield
Postby Gary1958 » Tue 20.03.2012, 10:08
Hi Dave,
thanks for clearing that up for me.
I'm not sure what's in the "Coffee" shops these days?
Gary1958
Re: turbo shield
Postby HJ2 » Tue 20.03.2012, 11:00
Nothing... they are only there to entertain the tourists ;-)
Did you get he bolt then?
Re: turbo shield
Postby epipete » Tue 20.03.2012, 15:50
If the heads shear off, given the location, how di you get the 'stubs' out?
Pete
Re: turbo shield
Postby muley » Tue 20.03.2012, 19:46
epipete wrote:If the heads shear off, given the location, how di you get the 'stubs' out?
Pete
I didn't - I took the whole shooting match off - got the turbo rebuilt and the studs drilled out.
All replaced with brass screws smothered in copper grease.
Re: turbo shield
Postby P@ulW » Tue 20.03.2012, 20:17
Is the turbo heat shield strictly necessary? Mine was destroyed in getting the turbo off to replace a cracked manifold. So lightness has been added...
P@ulW
Re: turbo shield
Postby Gary1958 » Fri 23.03.2012, 10:50
lansledj wrote:Gary left to right :D
David,
further to your reply i've still not been able to remove the heat shield. However, having seen a second hand turbo unit for sale via Steve Strange on flea bay (its still there if somebody needs one) I can now see exactly what is required and understand how they may stick etc. I'm glad i didn't try and turn the spindle as i could easily have broken it off :lol:
Gary1958
Re: turbo shield
Postby HJ2 » Fri 23.03.2012, 11:21
I thougt i gave the hint away 8)
If you need more info / pics, look here:
viewtopic.php?f=79&t=16507
Re: turbo shield
Postby Pascal » Sat 20.10.2012, 10:55
Hello,
i don't manage to remove the two screws either, sorry to ask as i'm french and my english is not too good,
and i want to be sure that i read you properly.
if the top screw is broken (shear off), i think it is not a serious issue, i think it is not in solid 'mass metal.
what about the side one then ? This one seems to be screwed in the solid metal. If broken, does it mean a trip to hell ?
Pascal
2020 May 21- Ieper Lotus Day ! I'm not ready ! I need a hair cut ! Pascal - North of France - 1991 SE Turbo Calypso (faded to pink) Red and an additional Elise somewhere in the garage
Pascal
Re: turbo shield
Postby norman lovie » Sat 20.10.2012, 11:44
I take the "Queen of hearts" pragmatic approach to these bolts - "off with your head"
then fix the problem later - usually a drill out and helicoil - or i,d spot weld a threaded shank onto the sheared thread - then use a nut and washer versus a bolt
norman lovie
