Dump Valve advice please?
Postby paulous » Fri 28.06.2013, 23:19
Hi,
I recently bought this Bailey DV24 dump valve on eBay from someone who had removed it from their Elan. It came with a turbo hose and the fitting kit so was really easy to fit :
At first I quite liked the noise, but after a few days (ok minutes) the novelty soon wore off!
Is there any way I can make it queiter?
I'm guessing the answer is probably no, short of wrapping the whole thing in foam - but I'm not sure that would be safe or if it would even work.
I'm wondering however if I could replace it with a Bailey DV30 recirculating dump valve which I think will simply fit on the same samco hose but will then need somewhere to plumb the outlet pipe in to. The logical place obviously is the trash can but I don't really want to cut that so maybe I could just attach a length of hose to a breather filter? Would that work?
Can anyone offer any advice? Is there a better alternative to the DV30 ?
Basically I want a fairly quiet dump valve but don't want to spend a fortune and don't want to get too complicated as my mechanical skills are very limited. I think I can handle a small amount 'whoosh' noise but not the very loud 'whoosh' the DV24 gives.
Thanks,
Paul
S2 No.285... Then sold it 2014
paulous
Re: Dump Valve advice please?
Postby DeanG » Sat 29.06.2013, 17:03
There are varieties that allow plumbing the vent to the bottom of the car. People have used K&N style filters on these to suppress noise. Mine has no filter and just vents down.
DeanG
Postby theelanman » Sat 29.06.2013, 20:46
Vent it back into the air filter/trash can.......:-)
Postby Rice crispy » Sat 29.06.2013, 23:15
I think you will find you can't make yours quieter as it only vents to atmosphere, I have a dv30 which is a recirculating valve and is almost silent as i vent it back into the trash can
Rice crispy
Postby steve matthews » Sun 30.06.2013, 00:38
The valve exits the excess air through the 4 cut outs at the end of the fixture at vacuum hose.
If you could cut out and place a coffee can over this area the noise will be baffled.
I have seen a beer can used :shock:
Or get a different valve.
Steve
steve matthews
Postby djcar » Sun 30.06.2013, 03:12
I like my dump valve sound. not sure of the make
djcar
Postby paulous » Sun 30.06.2013, 16:04
Thanks for the advice so far, I'm thinking recirculating valve is the way to go.
Has anyone fitted the Forge FMDV008?
paulous
