Wastegate wiggle
Wastegate wiggle
Postby mauveelan » Mon 19.08.2013, 23:17
Hi Guys I am new to this Turbo business and all its associated bits and pieces ( brought up on Alfas with Webbers and Dellortos) have read a lot about the wiggle and thought I would try wiggling my wastegate tonight ,seems OK but movement is only through 45 degrees does anyone know if this is the norm.
Richard
mauveelan
Re: Wastegate wiggle
Postby Rambo » Tue 20.08.2013, 08:52
I thought the movement of the actuator rod was in a horizontal plane ? Correct me if I'm wrong ;-)
Postby rip » Tue 20.08.2013, 09:37
Is it not working then?
You should only need to wiggle it free if it seizes open or closed.
Postby mauveelan » Tue 20.08.2013, 10:11
Thanks for the reply, as I understand it the actuator rod operates ( push/pull ) on a lever which in turn operates a spindle (rotational) into the wastegate .
Question is degrees of movement on the lever/spindle ??
Richard
mauveelan
Postby Dcp1 » Thu 17.10.2013, 21:25
Hi has anyone a pic of this said actuator as I think my waste gate is stuck from the feedback I have been getting,cheers
Dcp1
Postby epipete » Thu 17.10.2013, 21:30
Check out the Wiki, there it shows the whole unit removed from the car for clarity, but to release the waste gate all you need to do is grip the shaft with something (pliers, mole grip, etc) and move it from side to side.
Postby Rambo » Fri 18.10.2013, 09:00
Postby Dcp1 » Fri 18.10.2013, 10:36
Hi all moved the rod to free the waste gate,seems to open and close as you can hear the change in tone in the tick over but still the boost gauge doesn't seem to move
Dcp1
Postby Rice crispy » Fri 18.10.2013, 23:57
Check the earth on the boost gauge transducer on the inner wing, drivers side has a red/orange rubber cover.
Rice crispy
