Can anyone advise what this is
Postby Rob P » Fri 15.04.2016, 16:25
Guys I am trying to identify the part below which Looks like it should have two pipes attached but doesn't on my car. This was mounted on the rear of the Air filter mounting bracket. It has a connection electrically but as you can see no pipework.
Part disconnected and hanging loose to show pipe connections
Photo showing position of the part mounted at the rear of the Air Box mounting
Wider view of positioning of this part
I have looked through the parts manual from cover to cover and can't see anything that looks like this so looking for the well educated LEC forum to help identify
Rob P
simplify and add lightness
1997 Lotus Elise S1 - Metallic Racing Green
Rob P
Re: Can anyone advise what this is
Postby Simon_P » Fri 15.04.2016, 16:57
Rob,
That is your wastegate actuator valve.
Postby John_W » Fri 15.04.2016, 17:10
Ah...
Do you have a MBC fitted?
That's the boost solenoid valve which controls the boost level and is itself controlled by the ECU.
As there are no pipes attached to it, this makes it sort of difficult for it to accomplish its aim in life.
I think you need to check your small-tubing plumbing to and from the turbo.
Postby Rob P » Fri 15.04.2016, 19:26
Thanks Guys,
I assume this is disconnected due to my Turbo being none standard and having a boost controller and a different Boost Gauge to standard then, the Boost Gauge Transducer is also disconnected as far as pipework is concerned.
I suppose I will continue to find anomalies as I go along and this is to expected when buying a car that is so none standard :-(
Question now is do I take these standard parts off the car and store them some where safe, I can't think I will ever be returning the car to standard and adding lightness is the Lotus way :lol:
Thanks Guys
Rob P
Postby John_W » Fri 15.04.2016, 20:38
Sorry, I forgot you're different :lol: .
If you do leave the bits on the car, it would be good to put caps over the air pipes to stop crud getting in.
Postby Rob P » Fri 15.04.2016, 20:52
yeah buying a car that is different has and I am sure will continue to be a challenge. I still love it to pieces though, between the cursing and swearing that is :lol:
Picture below shows the pipework to the Boost Controller which sits inside the car and mounted on the dash (White pipe)
picture below showing another element of the Turbo boost control with nothing attached
I assume taking them off the car and detatching from the electrics shouldn't cause any issues? Might be tomorrows job :-)
Rob P
Postby John_W » Fri 15.04.2016, 21:16
They don't seem to be doing anything anymore, so you might as well do what you suggested and add lightness. Don't throw them away - they will be needed if you ever go back to normal.
The orange rubber covered one is for the boost gauge, by the way. I don't suppose you have a standard one of those either.
Postby GeoffSmith » Fri 15.04.2016, 22:07
Rob P wrote:…and a different Boost Gauge to standard…
John_W wrote:The orange rubber covered one is for the boost gauge, by the way. I don't suppose you have a standard one of those either.
You could be right John. :roll:
Postby John_W » Fri 15.04.2016, 22:25
:smt072 :smt110 :smt116
Where's Monty's old Bart Simpson mooning smiley when you need it?
Postby Rambo » Sat 16.04.2016, 20:12
John_W wrote::smt072 :smt110 :smt116
This one John ?
Rambo to the rescue, yet again ;-)
Postby John_W » Sat 16.04.2016, 21:22
:lol: Thanks, Mark.
Postby HJ2 » Sun 17.04.2016, 09:00
:lol: :bowdown:
Postby GeoffSmith » Sun 17.04.2016, 09:37
Where's the LEC sticker?
Postby Rob P » Sun 17.04.2016, 11:59
Unnecessary parts removed, the car has this system fitted, perhaps I need to read this manual and work out where all the tubing goes 8)
Manual,
Boost Controller
Boost Gauge and other matching instruments
After removing the aforementioned items took the car out and all good. Items will be stored in a safe place for future use if required.
Thanks for the feedback guys
On to the next job
Rob P
Postby GeoffSmith » Sun 17.04.2016, 15:29
GeoffSmith wrote:Where's the LEC sticker?
Oh, there there they are...
Happy birthday Rob...
Postby John_W » Sun 17.04.2016, 16:08
:clap:
Excellent stuff. I am now spoiled for choice.
:mrgreen:
Postby Rambo » Sun 17.04.2016, 17:55
Anything else Geoff ? Like a photo of old Grecian, Timmo's boobs or Pantz :twisted:
Postby Rambo » Sun 17.04.2016, 18:01
Back on subject Rob, it's a pain when normal things go wrong with the M100 but when they go wrong with an Elan that has been heavily modified... Nightmare :?
Postby GeoffSmith » Sun 17.04.2016, 18:02
What?
Postby Rob P » Sun 17.04.2016, 19:49
Rambo wrote:Back on subject Rob, it's a pain when normal things go wrong with the M100 but when they go wrong with an Elan that has been heavily modified... Nightmare :?
A nightmare indeed Geoff, but having taken her out for a nice trip today and thrown her around a few country lanes with no issues I am once again happy with her...............for now.
Have to have a little chuckle at the off topic stuff, you guys clearly know each other well to be able to take the ribbing that goes on :-)
Rob P
