I've ruined my car..........
Postby simonbuk » Thu 25.10.2018, 16:51
Whilst taking advantage of some of my car coming to pieces, I did the following.
The turbo got rebuilt and I got them to increase the wastegate hole up to 21mm.
I removed the pre cat and fitted one of Piper's pre-cat downpipes.
It now drives like a bag of sh*t. I mean nearly undrivable. Rubbish.
Overboosts really easily. You try to push on at all, and it just goes through the roof and EML comes on.
It's like I've got no boost low down for a while, then starts to build - BANG !!
I feel like putting everything back how it was at this point it's so awful.
What have I done ??
(Oh, and I think I've burnt my alternator out too - just to top it all).
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: I've ruined my car..........
Postby Brit-Car-Nut » Thu 25.10.2018, 17:33
Have you verified that the boost control flap in the wastegate is opening?
Have you verified that the vacuum hoses between the vacuum boost controller and the manifold are hooked up correctly as well as the vacuum hoses to the boost control solenoid?
Has the boost control solenoid failed? If the boost controller doesn't open, you will over-boost all the time.
Are you running a Mountain Chip or a manual boost control of some sort?
Postby simonbuk » Thu 25.10.2018, 17:43
No performance chips currently installed.
I haven't verified too much at the minute to be honest. Spent enough time trying to start/charge the car, identify burning smell, go get gallon of petrol, swap battery out of another car, etc,etc. Just got f*cked off !!
I did have a quick look around vacuum hoses as when I change up the turbo whistle is not as before. Really quite different. So thought a hose might be off.
Need to gather some info, charge battery overnight, and then tackle with a fresh head full of others ideas tomorrow !!
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby Brit-Car-Nut » Thu 25.10.2018, 18:09
I suggest a bit of calming down, take a break and start from scratch.
If the wastegate isn't opening at all, then you need to solve that first.
It could be due to seizure, damaged/missing vacuum hose, bad control solenoid (at base of the Air Cleaner, damaged/missing vacuum hoses going to the manifold.
Also, make sure the vacuum hose to the MAP is installed correctly.
Use the manuals to be sure everything went back together as it should.
Postby simonbuk » Thu 25.10.2018, 18:48
Yes calming down now, down the pub .....
I now can't picture how to view the wastegate ? I obviously have to remove the heat shield first, it's then just obvious isn't it and in view ?
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby alan e » Thu 25.10.2018, 19:10
Who did the work ?
2010 black evora
Austin 7 1932 box saloon
MG ZS EV
alan e
Postby simonbuk » Thu 25.10.2018, 19:12
My mechanic !!
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby alan e » Thu 25.10.2018, 19:35
Have you taken it back to him so he can take a look at it to see why its so running so bad.
2010 black evora
MG ZS EV
alan e
Postby simonbuk » Thu 25.10.2018, 19:37
Only just drove it for the first time today. Gave him a ring but he was on the golf course today !!
I will obviously talk to him but currently unavailable.
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby alan e » Thu 25.10.2018, 19:41
There is a posting on here somewhere that shows you how to test the waste gate using a pump to see if it moves.
2010 black evora
MG ZS EV
alan e
Postby Rambo » Thu 25.10.2018, 19:46
alan e wrote:There is a posting on here somewhere that shows you how to test the waste gate using a pump to see if it moves.
If it helps, I'm sure it was Phil (Lotusflashermanphil) who posted this handy tip. I will see if I can find it
Postby RonR » Thu 25.10.2018, 19:47
Hi Simon,
If you're at your Orpington address I have an Elanscan cable you could borrow but unfortunately my Laptop battery only lasts a few minutes before it dies.
I could lend you an Elanscan Logger though, you'd just have to get the file from the SD card onto a PC...
Cheers,
Ron
Postby alan e » Thu 25.10.2018, 19:53
And if you are in Worthing i have one you can borrow but you will have to supply the laptop.
2010 black evora
MG ZS EV
alan e
Postby simonbuk » Thu 25.10.2018, 19:54
Thanks for the offer Ron. I'm actually at my Worthing address and my Elan Scan cable is in Orpington, whilst my laptop is with me in Worthing........bum.
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby simonbuk » Thu 25.10.2018, 19:56
alan e wrote:And if you are in Worthing i have one you can borrow but you will have to supply the laptop.
Thank you - might take you up on this.
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby Rambo » Thu 25.10.2018, 19:56
Postby simonbuk » Thu 25.10.2018, 20:18
Rambo wrote:Here we go. Phil to the rescue :smt023
viewtopic.php?f=31&t=25846&p=343917&hilit=Wastegate#p343917
Great, thank you, got a foot pump but might have to stand on something high up to use that !! I'm sure I can get hold of a pump of a local kid.......
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby Rambo » Thu 25.10.2018, 20:22
You can get a cheapo bike pump and adaptor from your local Sports Direct. You'll probably get a football chucked in for under a fiver :lol:
PS this pump/adaptor trick is also good if you get water under the petrol flap and it won't drain away. This is a Muley tip I seem to remember ??
Postby simonbuk » Fri 26.10.2018, 12:05
How do you get these clips off ?! Are they crimped on and you have to break them to get them off ?
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby dapinky » Fri 26.10.2018, 12:47
Basically, yes - they are an 'industry standard' crimp fitting, but without the correct tools you'll never get a good seal at home (especially with the limited access) if you disurb them.
I did it the simple way by cutting through the pipe and getting a small screwdriver into the crimped bits to open them up a bit, followed by some butchery with pipe grip pliers, then used silicone vacuum hose and jubilee clips to replace it.
