Help to identify part and purpose
Postby Emlyntaylor » Sun 03.02.2019, 15:47
Hi
I am looking for help to identify the ‘terracotta’ coloured part in the bottom left of this pic, mine has perished and has a hole. What is the purpose of the part and what effect will having a hole have?
All help appreciated
Emlyn
1990 Elan Turbo SE, 1995 Esprit S4s
Emlyntaylor
Re: Help to identify part and purpose
Postby alan e » Sun 03.02.2019, 16:00
That is your turbo transducer is your boost gauge working ok ?.
2010 black evora
Austin 7 1932 box saloon
MG ZS EV
alan e
Postby tigerdog » Sun 03.02.2019, 16:39
Your profile doesn't say where you're located; I may have one lurking somewhere in storage here in Calfornia. If the boost gauge is working, you could
a) patch the hole and carry on,
b) find a replacement somewhere, or
c) replace it with a mechanical boost gauge as I did, and eliminate the part. Click for picture and process.
Postby Simon_P » Sun 03.02.2019, 19:25
The S2 doesn't have the rubber cover and looks like the same part, so you could just ignore it.
Postby dapinky » Sun 03.02.2019, 20:24
I stand to be corrected by someone with more specific knowledge than myself......
...... but (like Simon alludes to), I believe that the rubber sheath is more to keep weather out than actually performing a vital function of operation. As such, i would use a suitable glue to repair any splits and rotate it so that the ugly bit is underneath and hidden from view.
Postby Rambo » Sun 03.02.2019, 21:08
Some of the later boost transducer sheaths/gaitors were grey rather than terracotta/orange :wink:
Looks like your terminals could do with a good de-rust or clean up :shock: As Alan has mentioned previously, any problems with your boost gauge ?
Postby Emlyntaylor » Sun 03.02.2019, 21:16
Thanks all, boost gauge was fine. I have patched...with silicone sealer :s and will rotate to hide, but not before I clean up the terminal.
Thanks all very much appreciate the help!
Emlyn
Emlyntaylor
Postby John_W » Sun 03.02.2019, 21:43
That’s what I did with mine when a mouse chewed its way through it about 15 years ago!
:mrgreen:
