My questions are: What does it do? where does it start from at the manifold? is there a required union to attach it to and what diameter is it?
The answer to one or more of these questions would be appreciated
lotustonybassplayer wrote:it goes to the vacuum reservoir behind the wheel arch liner. it starts from the rocker cover right hand side at the rear just in from the corner you should see a little spout where it connects to. It usually has a right angle rubber connector, i've just replaced mine it comes from a mini distributor £1.75 on Ebay part no 12B2062
GeoffSmith wrote:Possibly the heater valve.
johnj wrote:I think that if you look almost directly down from where the end of the broken hose is, there is a Y shaped hose. If you follow the Y back towards the bulkhead there us a circular metal 'thing' (sorry not mechanic'). It has a nipple at the bottom. I think the pipe connects there.
johnj wrote:See attached picture, bottom hand pointing to the Y hose. Top hand pointing to the metal piece with tube attached.
Hope this helps.
dapinky wrote:Here are a couple of pages from the workshop manual, and a photo of my old engine bay (without engine) which may help you to trace what you have, and what is missing/broken/detached.GeoffSmith wrote:It runs from the heater unit to the vacuum reservoir in the wing.
[/quote]GeoffSmith wrote:It runs from the heater unit to the vacuum reservoir in the wing.
GeoffSmith wrote:Red and blue pipes both go to the reservoir - no non-return valve as far as I can remember.
roy666 wrote:Hi Scotlan.. I had (have) exactly the same issue..looks like. Gerald at GST Performance just plugged the pipe up for me saying it was redundant. No isues from it since. cheers Mike.
dapinky wrote:Mike (and Tony),
The pipe which Gerald has plugged may well be redundant on yours - there are 2 nipples next to each other on the back of the inlet manifold - 1 has the black elbow attached and goes to the reservoir (and needs to be fitted to allow heater to function)....
.... the 2nd one is usually 'capped' when the car leaves the factory. (I assume that it had a specific function when the engine was used elsewhere, but not needed on an Elan).
This 2nd nipple needs to be capped (or in you case, a pipe fitted and plugged!) so that there is no vacuum leak which will affect the sensors for the engine management.
However
I would suggest that (judging from the length of pipe, and where it ends up) that someone previously has had a dump valve fitted, and used the 'extra' nipple to activate it, instead of fitting a 'tee' piece in another vacuum pipe.
Users browsing this forum: ludo and 1 guest
