No boost gauge indication under 2900rpm?
Postby Twayblade » Tue 08.06.2021, 16:58
Hi all- can someone enlighten me on what my boost gauge should be indicating when operating normally? I have an SE and I don't seem to have any boost indication (0bar boost)below 2900rpm? Above that and I get a boost indication 0.75 bar approx depending on how the car is driven
My understanding is that a boost indication up to 0.4bar is normal below 2900 rpm.
Could this be wastegate related?
Twayblade
Re: No boost gauge indication under 2900rpm?
Postby dapinky » Tue 08.06.2021, 19:04
The ECU is programmed to need to meet certain requirements before 'allowing' the turbo to boost.
It needs to be at a certain temperature, throttle opening and revs.
From memory, it is 3000rpm on a 'standard' memcal map, and drops to 2800 with an Everest chip. So, yours is behaving as I would expect. It is all done in an attempt to prevent the engine from blowing itself up.
Postby esprit888 » Tue 08.06.2021, 19:21
dapinky wrote:The ECU is programmed to need to meet certain requirements before 'allowing' the turbo to boost.
esprit888
Postby Twayblade » Tue 08.06.2021, 21:02
Thank you for the explanation, re assuring that nothing is amiss! just out of interest where do you get this info from?
Twayblade
Postby dapinky » Wed 09.06.2021, 11:03
Twayblade wrote:...... just out of interest where do you get this info from?
It's all on Alans 'Mountain Chip' website (link from the top bar of this site).
