tickover saga conclusion
Postby kbee » Fri 18.06.2021, 21:00
thought this info might help others, bought my S2 in April and was advised by the seller that the normal tickover speed was 1200 rpm . The saga begins , soon realised this was Bull**** and did the usual air leak and adjustment checks ,no luck .Did some research and found I had code 23 manifold temp low ,changed sensor ,no change.No check codes so research and a new IAC valve , the original sure enough was siezed.....result 950 tickover :x but only at some temperatures , more research :idea: changed ECM temp sensor :clap: 950 rpm . First Lotus and a baptism of fire . all thanks to the manual section .
kbee
Re: tickover saga conclusion
Postby Rambo » Sat 19.06.2021, 07:18
And, of course, useful pointers from LEC members to all your problems :wink:
viewtopic.php?f=38&t=28623
Postby Rambo » Sat 19.06.2021, 07:19
But well done for sorting it. On to the next one now :twisted:
