Everest Chip and Boost
Postby Graaf » Wed 20.07.2022, 14:12
Hi All
I have an everest chip fitted to my SE but the boost never goes above 0.5bar - I know that the gauge can be out but it definitely doesn't seem to give any more umph than it did before.
When I initially bought the car it had a manual boost control switch which i took out and reconnected the pipework.
The facebook M100 group have suggested disconnecting the Boost solenoid and that this is the one nearest the front of the 2 fixed to the offside wing.
My car only has one solenoid and that appears to be the rearmost - there is space for another on the bracket.
Could this missing solenoid be anything to do with the problem?
I hope that the about is clear enough.
Graaf
Re: Everest Chip and Boost
Postby HJ2 » Wed 20.07.2022, 16:15
I would pull the air pipe between turbo and plenum so the turbine is visible and then feel if it spools without resistance first.
Postby Elanlover » Wed 20.07.2022, 17:51
I had a similar issue a long time ago. The problem turned out to be that the throttle cable wasn't taut enough so, with the pedal all the way down, I wasn't getting full throttle. An easy check would be to see how much slack is in the throttle cable and, if there's some there, tighten it up and go for a spin. Just be sure you don't tighten it too much such that your idle RPM is too high.
Postby Graaf » Thu 21.07.2022, 17:26
HJ2 - spins fine
Elanlover - you are quite correct. Adjusted the length of the throttle cable and now boosts up to about .9
Thanks all :cheers:
Graaf
Postby johnj » Sun 24.07.2022, 13:20
Thanks Elanlover fix worked for me. I reckon that should unleash an extra 50ish bhp.
johnj
Postby HJ2 » Sun 24.07.2022, 13:28
Powerrrrrr!
Postby steve matthews » Sun 24.07.2022, 16:46
:burnout:
steve matthews
Postby Graaf » Sun 24.07.2022, 18:24
Oh yes! :clap:
Graaf
Postby Elanlover » Sun 24.07.2022, 19:01
Glad to see it was a simple and inexpensive fix. That cable will stretch over time so a few checks from time to time are a good idea. One day it'll break like mine did. You might even be as lucky as me where it only 3 blocks from home - too close to call for a tow and far enough away to evoke much cursing as I pushed it home.
Postby Graaf » Mon 25.07.2022, 16:45
Thanks again for the tip.
Graaf
