So...which type of gasket is best?
Postby Ashaman » Thu 27.04.2006, 05:02
I have heard it both ways - and had both fail. Basically, I have only seen the stamped/sheet type, and the collapsable multi-layer type.
I was just wondering if anyone had a firm opinion one way or the other? I am putting my turbo back on, and I want it to be the last time until I decide to try a different model! Of course, then again I have heard some say the best gasket is NO gasket....Hmm....
Maybe it doesn't matter a lot, the failures I have had could be due to the nuts backing off; that has been a problem on all turbo-charged cars I have owned. This time however I have some Spira-lock fasteners I am going to try, so hopefully that is a thing of the past!
Ashaman
Postby joeisuzu » Sat 02.12.2006, 23:35
I don't use a gasket on my impulse RS, you could use some coppper gasket maker very thinkly to help it kind of seat up properly...
1991 Base model Geo Storm
1991 Loaded Isuzu Impulse RS
Saving for an Elan...
Its a bit hard for me to get online lately, so if I don't reply that's why...
joeisuzu
Postby Dave M » Sun 03.12.2006, 00:26
When I put the hybrid IHI/T3 on, I used no gaskets and the copper gasket goo. This was basically the stock setup. I had no leaks. When I replaced the bad gaskets in the last go around with the current T3, I did a stamped stainless gasket on both sides of the turbo spacer and they have been fine. http://www.prostreetonline.com/buy/t3_inlet_gasket/ The copper gasket between the turbo and the downpipe/O2 housing has also been great with no leaks. I bought it here and it appears to be the 100% real thing (no mixed metal that could melt at a lower temp) http://www.whimsie.com/coppersheetwire.html
If your surfaces are true, I'd probably go with the copper gasket goo. That way you have one less item to fail or have problems with.
Dave M
