TorqueHorse wrote:Roj,
Ahh, you've got a lot going on. I missed that video you already did where you had it in service mode and were able to "trick" the IAC to behave pretty well by unplugging, turning off, replugging, etc. It was idling pretty well, and then you took it out of service mode and WHAM, up up and away. https://youtu.be/iic_0ReaHK0
Since going in and out of service mode had such an effect, I went back to look at your elanscans to see what inputs are going to the ECU.
One thing that stood out to me is that your "Steering Load Normal?" is set to OFF, which means the ECU thinks your pwr steering pump is running and needs more engine to compensate.
On my elanscans, that tag is set to ON. Presumably it would come on if I did a hard turn, but I couldn't find a scan I did where I did a hard turn and recorded it.
This is one of the sensors that gets ignored during service mode (*need to triple check that is true) so it could make sense why such a change in behavior between service mode and not.
Any work near the radiator lately? There is a little wire that comes out of the bottom of the power steering pump and that should be plugged in and makes its way back to the ECU telling the ECU if the pump is hard at work or not.
Another avenue to explore in a darkening alley (fingers crossed).
chrism wrote:Well that's another itch scratched if you've found that the secondary throttle system has checked out as okay...
ps no need for a VAR decision:-
"At higher engine speeds the solenoid is de-energised and vents the actuator capsule to atmosphere allowing the throttles to spring open.
To reduce drain on the battery, the solenoid valve is de-energised with ignition on and engine stopped." from an earlier post
ie de-energised solenoid = sec throttles open...BUT what if the actuator capsule doesn't vent when ign's switched off? Say it's seized, rusty or blocked up somehow. I presume the actuator capsule vents to the atmosphere or the reservoir? If it can't vent could it flow out the wrong way as the ignition is turned on again and interfere with the sec throttle until it's 'all used up' by flowing the wrong way.
Fantasy on my part(?) - but could this explain the thumb-over-the-IAC-effect that we saw? Is it possible that the IAC and secondary throttle can interfere with each other in this way? Just a thought...
chrism wrote:Yes I can confirm TorqueHorse's observation and as you pointed out earlier the power steering switch (no.14) supplies the ecu with data to control idle speed.
The roj data in the first graph is the blue line at zero and my own data is the black line at "2":-![]()
Could you be the victim of a stored code, I wonder? Strange that it hasn't shown up in your paper clip test - even tho Inspector TorqueHorseclocked it in your EScan data
dapinky wrote:Well, I'm all out of ideas at this point - but that doesn't mean I'm giving up.
I know that you have 'sort of' done it in the first video, BUT, what would happen if you fiddle with the IAC in service mode to drop the idle (like you did).... but then you put it back into 'Normal mode' whilst the engine was running......
..... what I'm thinking is can we get it down low(ish) again, in Service Mode, then unplug the IAC valve before taking it out of service mode,
My thoughts are that at that point, the IAC valve should be nearly closed, and if it is disconnected, then it will stay where it is - whatever the rest of the sensors are saying/doing as there is no connection. Then by bringing the other sensors online, what happens to the idle speed?
This isn't any sort of 'fix' as such. but may help to establish if the IAC valve is closing enough to make a reasonable seal in the plenum.
Other than that, I would be looking at taking off the whole plenum and checking that the IAC is sealing fully by examination and blowing smoke through it whilst you can see what is actually happening.
Oh, and if it helps, there is a really easy way to set Service Mode on and off with Elanscan plugged in - on all my Elans, one of the first thing I do is splice a wire into the two relevant wires just inboard of the ALDL plug, and run the splice through a simple rocker switch which is positioned in the top face of the glovebox - then with ES plugged in (or not!), you only have to open the glovebox and flip the switch to complete the connection that the paperclip would be doing. It is the only accurate way to ever set the idle speed as ES gives the 'correct' reading, but it needs to be in Service Mode to set it.
roj wrote:I also see this on the big wiring electrical PDF.
After Googling, I'm assuming that BU is for colour 'Blue'. Learning on the job here.
