CAMBELT PARTS
Re: CAMBELT PARTS
Postby Giniw » Fri 10.08.2012, 22:56
So, the different length is not important? (41.5" versus 42")
Well, I suppose that there is a tensioner ^^"
Giniw
Re: CAMBELT PARTS
Postby Brit-Car-Nut » Fri 10.08.2012, 23:55
Tension is adjusted with the PS Pump.
Re: CAMBELT PARTS
Postby Giniw » Fri 10.08.2012, 23:58
OK thanks: I am going confirm the order! =)
edit: done! \o/
Giniw
Re: CAMBELT PARTS
Postby madbilly » Wed 15.08.2012, 11:33
Belts don't need to be ordered from the USA, I think Camskill can supply them. If they can't supply the V-belts for the alternator and PAS then they are standard parts you should be able to get from any motor factors, and I'm sure the prices from Paul Matty, SJ's etc are competitive. As for the idlers and water pump (if needed/wanted) then they probably do need to be ordered from the USA.
madbilly
Return to Engine
