Happy New Year !!
simonbuk wrote:Thanks just found some threads regarding the cas bearing replacements.
Can't believe the belt is loose as it had its timing checked (and adjusted) not long ago but I will check tomorrow.
lotustonybassplayer wrote:I would check the adjustment of the sensor in the cas assembly. I had a rattle and it was the sensor touching the spinning part, the gap should be roughly the same as the spark plug from memory.
Brit-Car-Nut wrote:That movement seems to be the same as every CAS and engine I have checked.
alan e wrote:and good luck removing the belt cover to see if the belt is loose its not easy
