Cam journals worn........
Re: Cam journals worn........
Postby simonbuk » Sat 31.12.2016, 21:43
Brilliant !! Thanks Alan.
Happy New Year !! :cheers:
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby Rambo » Sun 01.01.2017, 10:25
simonbuk wrote:Thanks just found some threads regarding the cas bearing replacements.
Can't believe the belt is loose as it had its timing checked (and adjusted) not long ago but I will check tomorrow. :cheers:
Loose cam belt ? That sounds serious to me, even with my limited knowledge of cars :shock:
Did you have the tensioner replaced when you checked the cambelt ? Just a thought that the tensioner might be giving up if the cambelt is loose eg not providing the correct tension ?
What does the car drive like anyway ? I would expect you to have some loss of power issues/misfiring etc...under high rpm or full boost
PS I don't want to worry you unnecessarily but when I had the cambelt/tensioner/idlers replaced in my First Scudo van I was driving home from Edinburgh putting the foot down on an uphill section when I suddenly felt a loss of power, a bit of bucking then suddenly nothing. Dead ! Turned out to be a faulty tensioner according to the garage. It was allegedly new and faulty but, in my opinion, might not have been replaced and/or tensioned correctly. I never got to see the old tensioner or the faulty new one. Very convenient :?
Postby simonbuk » Sun 01.01.2017, 10:52
I have no other symptoms - drives fine, is smooth - no misfiring, full boost, good fuel economy.
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby lotustonybassplayer » Sun 01.01.2017, 13:02
I would check the adjustment of the sensor in the cas assembly. I had a rattle and it was the sensor touching the spinning part, the gap should be roughly the same as the spark plug from memory.
lotustonybassplayer
Postby simonbuk » Sun 01.01.2017, 13:07
lotustonybassplayer wrote:I would check the adjustment of the sensor in the cas assembly. I had a rattle and it was the sensor touching the spinning part, the gap should be roughly the same as the spark plug from memory.
Ok thanks, was it easy to take to pieces ? I'm worried that I'm going to screw up a whole load of timing !!
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby lotustonybassplayer » Mon 02.01.2017, 15:08
The black plastic cover can just come off 3 screws/bolts 4 or 5mm i believe . not difficult at all really :D
lotustonybassplayer
Postby simonbuk » Mon 02.01.2017, 15:20
Well I can just about get a feeler gauge between the sensor and the wheel but it does meet a bit of resistance when passing it through.
Can somebody please tell me if there should be any play in the wheel, I have a couple of mm when I turn the wheel back and forth.
Hopefully this might work -
https://1drv.ms/v/s!AkPH0GVEcqXVgeBA6NbQTNcZF03uEw
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby Giniw » Mon 02.01.2017, 15:38
If I remember well I had (edit: and probably still have) a similar amount of movement.
Giniw
Postby Brit-Car-Nut » Mon 02.01.2017, 17:32
That movement seems to be the same as every CAS and engine I have checked.
Postby simonbuk » Mon 02.01.2017, 17:40
Brit-Car-Nut wrote:That movement seems to be the same as every CAS and engine I have checked.
Ok cheers. :cheers:
There does seem to be a small amount of oil underneath it but not much and I couldn't get any sort of sideways or up/down movement from the shaft, so I'm thinking less and less a CAS problem.
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby simonbuk » Tue 03.01.2017, 21:21
alan e wrote:and good luck removing the belt cover to see if the belt is loose its not easy
Just been looking into this - looks like you have to remove the engine mount bracket to get to the last bolt to get the cover off - F*cking hell !! :smt013
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby HJ2 » Tue 03.01.2017, 21:50
:smt033
Return to Engine
