by Doc Fizzix » Sat 29.10.2005, 18:45
Just for over kill
Doc Fizzix
by John_W » Sat 29.10.2005, 20:20
M100,
Interesting. What's it made of? Mine is plastic, which of course bends a bit and can't be held in very securely with the bolt, which is why people talk of using sealant as well as the O-ring. Yours looks like metal.
Also, what does the other side look like? Mine has a 1/2 cm high circular plastic boss on it (about 3cm diameter) onto which the O-ring fits.
- Heid-bummer
by Twayblade » Sun 04.04.2021, 19:57
does anyone know the dimensions of the two O ring seals referred to in this thread?
Twayblade
by Fredjohn » Sun 04.04.2021, 22:47
Not a direct answer, but they are still available from SJ Sportscars. Part no. A100E6562S
by Twayblade » Mon 05.04.2021, 16:05
I was asking for the dimensions because I was thinking of trying an FFKM heat resistant O ring on the cam blanking cover as it seems the std nitrile ones used in this location deteriorate over time.
Twayblade
by KenS » Mon 05.04.2021, 16:25
I have been using these:
Not sure where I got them from, they have an 'x' cross section, with 30.4mm OD, 23.6mm ID. But Simons looks a very good deal, especially being viton.
S2 M100 NMY #285
N/A 2010 Evora
KenS
by Simon_P » Mon 05.04.2021, 16:25
I was offering Viton O-rings because...
Twayblade wrote:it seems the std nitrile ones used in this location deteriorate over time.
And Viton O-rings don't - It ts a well trodden path
by Twayblade » Mon 05.04.2021, 17:37
thanks Ken and Simon for the info,
4 should do Simon.
well trodden path indeed, there is so much info on here, I did not find my way to the thread you refer too otherwise I wouldn't have posed the Q .
how do I pay you?
Twayblade
by Simon_P » Mon 05.04.2021, 18:53
It's always worth asking! The index system on LEC is people's memory, sometimes you have to know that the post exists and then what to search for. I searched for Viton, so im not surprised that you didn't find it.
Please PM me your address and I ll get them in the post to you.
Return to Engine
