Oil Filter
Oil Filter
Postby Galsia » Mon 01.12.2008, 09:47
Galsia
Re: Oil Filter
Postby ailwyn » Mon 01.12.2008, 09:49
It's a Fram PH6811, easily obtainable, so your garage should be able to source one.
Re: Oil Filter
Postby Specky » Mon 01.12.2008, 11:06
Re: Oil Filter
Postby dapinky » Mon 01.12.2008, 12:21
I got one from Halfords (I was in a hurry) - can't remember which one it was, but it was in stock (part number OF20 rings a bell????). Not listed for the elan in the book on the shelf, but the guy on the parts desk can search for it on the computer.
Re: Oil Filter
Postby ksgrimsr » Tue 02.12.2008, 19:16
I also just changed my oil filter for the first time since I got my Elan. I noticed that both the filter I removed and the new one I installed (Fram XG3593A from one of the cross reference lists on this forum) lack an integral check valve like I'm used to seeing on the filters I use for one of my other cars. Is there a filter cross reference that includes the integral checkvalve, and are such filters suitable or unsuitable for the Elan?
Without the integral check valve, removing the filter was a bit messy and I was unable to avoid spilling oil down the backside of my engine and down my arm (I was spilling oil before I even had the filter unscrewed all the way). A little oil on the engine is a great dirt magnet as all the road dust sticks to it, and getting the area squeaky clean afterwards is a nusiance. Obviously, I had the oil drained before I unscrewed the filter, but is there some special technique (or filter with integral check valve) that will reduce the spillage?
Knut
ksgrimsr
Re: Oil Filter
Postby GeoffSmith » Tue 02.12.2008, 21:14
I caught all but a couple of drops in a plastic bag Knut.
Re: Oil Filter
Postby tigerdog » Thu 04.12.2008, 18:22
GeoffSmith wrote:I caught all but a couple of drops in a plastic bag Knut.
The rearranged componentry and standard air conditioning on Fed cars dramatically complicates oil changes compared to UK cars. While at Hethel, I was stunned at the access and how much easier this task must be on a UK car. As for filters, Knut, I went with a Mobil 1 M1-104 after a look around the web. More expensive but reportedly better-made inside than Frams. I also trained my local oil change shop to do the work. I take in oil and filter, they do the hard part then wash off the underside of the car and dispose of the old oil and filter for $18. Money well spent, I think.
Re: Oil Filter
Postby Ekapol » Sun 25.01.2009, 07:04
For me, always Purolator Pure One: Part # PL14459
Specifications:
Anti-Drain Back Valve Yes Height 2.95
O.D. 3.15 Relief Valve P.S.I. 12-15
Threads M20x1.5 Type of Filter Spin-on
Weight 8.14
Ekapol
Re: Oil Filter
Postby L.G. » Mon 09.02.2009, 00:17
Both the oil and air filter is listed on halfords book on the shelf now. (may have been sometime)
L.G.
'95 S2 driver #286
L.G.
Re: Oil Filter
Postby M100 TWO » Sat 21.03.2009, 19:22
Lotus are now supplying a Crosland oil filter number 672 the body is the same as the original white one. Lotus oil filter wrench that fits the dimples on the end of the original also fits the Crosland so one can assume the Crosland is the same but it is half the price of the white one from the Lotus dealers.
john
M100 TWO
Re: Oil Filter
Postby clemo » Mon 23.03.2009, 21:48
mann filter & fiam is also available from tradepart auto factors such as mills
also champion ones are/were available at halfrauds.
clemo
Re: Oil Filter
Postby L.G. » Sat 28.03.2009, 18:50
And is champion a good filter, any ideas? I bought one but I don't know the brand too well...
'95 S2 driver #286
L.G.
Re: Oil Filter
Postby M100 TWO » Sat 11.04.2009, 10:58
having done an oil change and comparing the two filters I am confident that the Crosland filter number 672 is the OE from Lotus!!! keep smiling
diff
M100 TWO
Re: Oil Filter
Postby Enright » Sat 11.04.2009, 11:38
You're probably right. Crosland used to be based in Nottingham and sold to a lot of OEM's.
Not any more. :(
Re: Oil Filter
Postby GeoffSmith » Sat 11.04.2009, 12:07
Wiki updated - where did you get it from John?
Re: Oil Filter
Postby M100 TWO » Sat 11.04.2009, 13:51
Geoff it is what Lotus are now suplying as the oil filter for M100
diff
M100 TWO
Re: Oil Filter
Postby DeeAitch » Mon 27.06.2011, 19:28
Local dealer also supplied a Crosland 672 this week - they say this is what Lotus now supply. Have placed another order to see if it is a temporary thing :twisted:
The Crosland filter is not the same as the white OE one they supplied me with last year - maybe it was old stock?
Dia is same but Crossland is longer (Not so easy if to fit if, like me, you go in from the wheelarch)
Also the seal is a different style.
Thread is correct so it does fit.
Not so happy that they pass it off as OE - and charge the OE price for it!
DeeAitch
Re: Oil Filter
Postby andrewp » Mon 31.10.2011, 05:04
I think (hope?) the concerns about the quality of aftermarket oil filters have been exaggerated in the past. As yet, I have not seen the "orange can of death" issues about Fram oil filters that are common on some internet sites. At the school shop we go through vast amounts of cars (literally cases and cases of Fram extra guard filters a year) and I have yet to see one Fram oil filter return split or leaking. I will say the wall thickness of the orange-canned Fram does not seem as great as the original Lotus filter. Other companies have filters that seem more robust.
The price of Fram filters has crept up every few months (at least here in Canada) for a few years to the point a more robust filter can be had for a few pennies more. Perhaps I am imagining this but does Walmart seem to have $2 "jumps" in filter prices at select times of the year? Where possible, I use NAPA-brand filters which are re-badged WIX filters.
AP
andrewp
Re: Oil Filter
Postby Fourdoorcat » Sat 04.02.2012, 02:37
Here is some oil filter information that has been on the web for a while. It does make for interesting reading.
http://minimopar.knizefamily.net/oilfil ... e.html#wix
"Never ascribe to malice that which can be perfectly explained by stupidity"
Fourdoorcat
Re: Oil Filter
Postby peteoddcar » Wed 29.02.2012, 21:28
HI y'all ,
I have just fitted a K&N on Ebay http://www.ebay.co.uk/itm/390293777917? ... 1497.l2649 very quick delivery at what I thought was a a good delivered price.
Looks nicely made and has a non return valve and the nut on the can which should make it much easier to remove :D .Anyone had any experience with these :?:
It was a doddle to change the filter with the driveshaft removed - 8) BUT THATS NOT how I normally do it ! :wink: just seemed like a good idea whilst I await the arrival of the replacemant driveshafts
I also noticed quite a lot of scratching scuffing on the sump. as well the prongeron. :shock:
Might check the ride height when its screwed back together, as its fresh scratches and I fitted adjustable spring seat dampers last summer
Pete
peteoddcar
Return to Engine
