CAMBELT PARTS
CAMBELT PARTS
Postby Bolsom » Sun 22.11.2009, 09:49
I am going to change my cambelt. The car (91SE) has done 31K miles and I doubt the belt has been changed.
I have looked at RockAuto and come up with the following:-
Belt Beck/Arnley 0260246 $20.79
W/Pump Dayco 84103 $41.79
Idler Pulley B/Arnley 0241150 $45.79
Tensioner Gates T41027 $50.79
These were shown for the 1991 Impuse RS. Can anyone who has done this please confirm that these are the right parts. I am going to the US in January and intend to get them whilst there, along with a heap of other stuff 'her indoors' will doubtless buy. It would be a pain to buy and bring back a wrong part.
Colin
Bolsom
Re: CAMBELT PARTS
Postby rip » Sun 22.11.2009, 10:01
It will take a while to cross-reference those, but they are all on here somewhere. If you've got them from Rock's Isuzu Impulse RS section, then they will be correct.
Remember to also include PAS & Alternator belts. :wink: . You need to be more careful with these as there are different lengths available.
Re: CAMBELT PARTS
Postby Denny » Sun 22.11.2009, 10:54
All the part numbers are listed on Wiki http://wikilec.9600.org/index.php/Main_Page under said titles, but look at Belts section for the cambelt number. I am doing the same thing when I go to the US and i found out that the whole kit weighs approx. 3 kilos so make allowance in the luggage :wink:
Denny
Re: CAMBELT PARTS
Postby theelanman » Sun 22.11.2009, 11:23
this was my shopping list.....although the prices may have changed
these are the bits I used....
Engine : Timing Belt
GATES Part # T169 {Automotive Timing Belt 1" x 50 3/32" (159 Teeth)}
Interference engine application $17.14
Cooling System : Water Pump
BECK/ARNLEY Part # 1312115 $47.79
Engine : Timing Idler
GATES Part # T42001 {Timing Belt Pulley Steel Smooth (60mm x 10.4mm x 31mm)} $48.79
Engine : Timing Belt Tensioner
GATES Part # T41027 {Timing Belt Tensioner Steel Smooth (60mm x 10.5mm x 30.5mm)} $52.79
so your list looks pretty similar....just the manufacturer that different :)
Re: CAMBELT PARTS
Postby Bolsom » Sun 22.11.2009, 11:32
Many thanks for the swift responses. I now have a firm list and peace of mind.
My next trick will be to fit the Everest closed loop chip I have in the assumption that the extra power will have
no effect on the old cambelt. Keeping the revs as normal that is.
Colin
Bolsom
Re: CAMBELT PARTS
Postby theelanman » Sun 22.11.2009, 11:40
Bolsom wrote:My next trick will be to fit the Everest closed loop chip I have
your belt bits will be fine.....more to the point how are your brakes :shock: :shock:
:-D :-D :-D :-D :-D :-D :-D :-D :-D
before I fitted my chip I did the brakes and exhaust...... :-D :-D :-D
Re: CAMBELT PARTS
Postby Bolsom » Sun 22.11.2009, 11:56
I've had the car for 16 years. Having scared myself a number of times I quickly fitted EBC greenstuff pads and grooved disks.
I worked in various places abroad for the first 7 years and so have only done 16K miles in the 16 years.
I can lock the front wheels with a good push on the pedal. I may get AP's sometime in the future, if the Euro
exchange rate improves somewhat. It has gone from 1.6 to 1.1 in the 7 years since I retired here. My
pension hasn't kept pace.
Colin
Bolsom
Re: CAMBELT PARTS
Postby Songbird » Sun 22.11.2009, 14:13
There is an auction for new Cam kit on flea bay at the mo .... 2 days to go.... but uk only
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
Songbird
Re: CAMBELT PARTS
Postby ashm » Thu 04.02.2010, 16:50
Just ordered the following cambelt change kit from Rockauto:
BOSCH 96065 Water Pump $ 40.89
DAYCO 84103 Timing Belt Component Kit $ 41.79
DAYCO 6PVK1040 Serpentine Belt $ 9.67
DAYCO 4PVK0695 Serpentine Belt $ 6.25
GATES T169 Timing Belt $ 12.63
Discount $ -5.56
Order Total $ 119.36
About £75 including US postage - bargain!
Same shopping list from SJS: £323.19.
Pretty sure the PAS/Alternator belts are right, but we'll see when they arrive.
Adam
ashm
Re: CAMBELT PARTS
Postby ovi » Thu 04.02.2010, 18:13
I've just received mine water pump.
RockAuto Cardone Select CSW 55-73619 $ 29.79 ! :banana:
ovi
Re: CAMBELT PARTS
Postby ashm » Thu 04.02.2010, 19:51
I found a weird thing with Rockauto was that the postage changed a lot for different components. When I selected a cheaper water pump, the overall order cost increased! The one I picked was not the cheapest pump, but it gave the lowest overall order cost.
Adam
ashm
Re: CAMBELT PARTS
Postby nsr250 » Thu 04.02.2010, 20:18
The shipping from RockAuto all depends on where the part is shipping from. I just placed an order this morning for 4 parts. It shipped from 2 different locations and I got charged twice for shipping. You may have ordered a pump that was shipping from a location further away.
Don
'91 Elan
'87 Milano
'91 318is
'02 Protege5
'02 DRZ400s
'91 VFR750
'98 VFR800
nsr250
Re: CAMBELT PARTS
Postby kenich » Fri 05.02.2010, 11:34
ashm wrote:Just ordered the following cambelt change kit from Rockauto:
Discount $ -5.56
Adam
I would of gave you some £££ for ordering double and could of saved even more on postage as I'm looking to order the same this month.
kenich
Re: CAMBELT PARTS
Postby ashm » Fri 05.02.2010, 13:55
Next time I'm in NYC for more than a few days I'll probably order several sets to bring back for LEC people.
This time I'm having it delivered a friend's house, then he'll keep it for me until I'm next there or he's next here; ordering a large amount of stuff would have been a bit unfair.
Adam
ashm
Re: CAMBELT PARTS
Postby Gee0 » Sun 07.02.2010, 12:36
I also need to do a cam belt in the next month or so,
I have a 1992 (K) SE,
Is the shopping list the same as above, (as peeps will know my knowledge is kept to driving)
Any help would be appreciated.
G
Gee0
Re: CAMBELT PARTS
Postby Giniw » Wed 08.08.2012, 18:28
Hello Everyone,
I need to change my timing belt (and the other belts, too)
And although I have read the WikiKEC, I must say I am quite nervous to order the wrong parts from rockauto ^^"
Here is what I believe is a proper set:
– Timing belt.
I found a timing belt kit (with water pump included): "DAYCO Part # WP169K1A" (here is the "more info" link: http://www.rockauto.com/catalog/moreinfo.php?pk=2455218 It seems the timing belt part number matches what the WikiLEC says \o/). On the other hand, the WikiLEC refers to the "BECK/ARNLEY Part # 1312115". Is that water pump a better alternative than the DAYCO one? Same question for the belt idler (WikiLEC refers to the "GATES Part # T42001") and for the belt tensioner (GATES Part # T41027): which one should I prefer?
– Aternator belt.
I may be wrong but it seems that only the "GATES Part # K040270" is available from rockauto. Still a straightforward choice I suppose?
– PAS belt (with air con)
When I am entering the "Isuzu part number 894362-7320" reference through the rockauto part search, it returns two entries. I guess these are actually the same belt?
As for the "DAYCO #6PK1045", it returns only one wich is 4 euros more expensive than the Isuzu. Is there any difference?
Same for the "Gates #K060415", it is the most expensive of the three PAS belts (1 euro more than the DAYCO).
Which one would you choose and why?
Thanks a _lot_ in advance =)
PS: As a newbie I am not really sure whether "upping" an old topic like this is appropriate here on LEC ... Please don't hesitate to tell me whether it's OK or not ;)
Giniw
Re: CAMBELT PARTS
Postby Giniw » Thu 09.08.2012, 23:33
I have been looking for a comparison between Dayco, Gates and Goodyear belts on the Internet.
It seems that the Gates products might be the best alternative over Dayco and Goodyear.
(I had not noticed before, but the WikiLEC seems to advise to choose Gates material, too!)
Giniw
Re: CAMBELT PARTS
Postby Brit-Car-Nut » Fri 10.08.2012, 01:37
Honestly, all three are reputable manufacturers. Their belts and hoses are on every US manfuctured car and they really are about equal. You don't have to worry about anything from them.
Re: CAMBELT PARTS
Postby Giniw » Fri 10.08.2012, 21:51
OK, thanks a lot!
I am nearly ready to send my order now. One last question though. As for the PAS with AirCon belt, the WikiLEC says to order the "Gates K060415 => K section 6 ribs 41.5"". That id points to a Gates belt on rockauto.com but they say it is a "GATES Part # K060415 K06 13/16" x 42 1/8" Micro-V AT Premium OE V-Ribbed Belt". Is it the appropriate one?!
Thanks in advance, once again =)
Giniw
Re: CAMBELT PARTS
Postby Brit-Car-Nut » Fri 10.08.2012, 22:13
Giniw wrote:OK, thanks a lot!
It is the correct part number
Return to Engine
