Help stuck in sainsburys and wont start now sorted
Postby tomac1975 » Tue 04.01.2011, 09:20
Help needed,
Car was a bit rough while driving to work, I'd put my foot down and it would stutter along then all of a sudden regain power.
I stopped for some milk, jumped back in the car and it would no longer tick over, the engine would not turn over, all it would do was backfire making every one on the forecourt jump and this is all it will do.
I now have to leave the car at the petrol station till i finish work :( :(
Any advise needed please before I call the RAC after work.
Cheers,
Tom. :( :(
tomac1975
Re: Help stuck in sainsburys and wont start
Postby Rambo » Tue 04.01.2011, 09:55
Have you tried the "paper clip" test yet ?
http://wikilec.9600.org/index.php/Check ... t_Problems
Postby bobbrown » Tue 04.01.2011, 13:25
Am I correct in assuming yours is a NA?
If so then I would suspect the distributor, mind did what yours is doing but would start most times till it decieded to breakdown on a roundabout 1/4 mile from home so walked back picked up the nice new dizzy and removed the old one and bolted on the new making an educated guess at the timing. It started first flick of the key.
It turned out that the rotor arm had lost the little spring clip that helps retain it on the shaft how it came out I have no idea but it was lying in the cap and looked like it had been there a while.
So I would say your first check would be the dizzy and you only need a cross point screwdriver.
If you need a new cap and rotor urgently let me know as I have a spare set brand new and can get them off in the post today.
Cost is £17.50 + postage.
The complete dizzy is/was available in the aftersales A100E6009S Distributor (NA) £51.06 but you will need to be quick and contact Specky if you want one.
Pacific Blue N/A
Postby tomac1975 » Tue 04.01.2011, 13:49
Thanks Bob, It is an N/A yes.
I'll have a look after work and be in touch regarding the rotor if ness.
Cheers,
Tom :)
tomac1975
Postby Specky » Tue 04.01.2011, 14:08
If you require a second hand Dizzy I can pop one in the post ASAP, I also have a new rotary arm if required.
I've got your PM as well.
Postby bobbrown » Tue 04.01.2011, 14:38
Specky, I was going to ask if you wanted a spare rotor but as you alreasy have one....... I ordered a cap and a couple of rotor arms from RockAuto before Xmas which I have now recieved.
I was working on the assumption one should have a spare dizzy with a new cap and rotor, always handy on a NA which I now have.
Pacific Blue N/A
Postby Specky » Tue 04.01.2011, 15:08
Yep I have a few as well, and a coil.
Postby Specky » Tue 04.01.2011, 17:07
tomac1975 wrote:Help stuck in sainsburys and wont start
Cheers,
Tom. :( :(
Go shopping, Think of it as free home delivery... :-D
Postby tomac1975 » Sat 15.01.2011, 11:06
Big thanks to Bob and Specky for advise and super speedy posting of parts. Changed distributer and all appears to be cool. And running soundly again.
Tom :-D
tomac1975
Re: Help stuck in sainsburys and wont start now sorted
Postby bobbrown » Sat 15.01.2011, 16:07
Out of curiosity did anything appear wrong with the old one?
Pacific Blue N/A
Postby tomac1975 » Wed 19.01.2011, 19:33
Hi Bob,
Yes similar to yours the metal contact on the rotor was damaged and was loose in the cap.
Sorry for late reply, only just noticed.
will photograph it when i get the chance.
cheers,
Tom.
tomac1975
Postby Lotusbongos » Wed 23.03.2016, 14:09
Hey Boys, think I have the same problem with my distributor on my N/A. Specky do you still have anymore distributor bits and pieces?
Lotusbongos
Postby clemo » Fri 25.03.2016, 08:46
intermotor daewoo esparro parts .
should still be available for any parts auto factors .
clemo
Return to Engine
Users browsing this forum: Google [Bot] and 4 guests
