Gaskets
Gaskets
Postby epipete » Thu 29.05.2014, 11:32
Trying to secure some new gaskets for Exhaust Manifold to Head, turbo to manifold, turbo to down pipe, do I need any others to refit the turbo? If so what?
It seems SJS can supply these but does any one know if they are competitively priced or if not them then who else?
Pete
Re: Gaskets
Postby Enright » Thu 29.05.2014, 11:45
By the time you've bought them individually - you might be just as well pricing up a complete head set.
I need some for the inlet side so we could come to some arrangement which might help you to offset some of your costs.
Alternatively, try RockAuto.co.uk, and have a search under 1991 Isuzu Impulse RS - that's what I'm about to do.
Re: Gaskets
Postby dapinky » Thu 29.05.2014, 11:54
Enright wrote:Alternatively, try RockAuto.co.uk, and have a search under 1991 Isuzu Impulse RS - that's what I'm about to do.
That's what I was doing whilst you were posting :D
Pete,
The Turbo to manifold & turbo to downpipe *should* be good to go lots of times - they are a solid metal (copper/brass/steel?) gasket which should just need a wipe over with fine wet&dry or wire wool to clean up any crabby bits.....
...the manifold to head gasket is a soft 'compressable' type and I've re-used them with success on many ocassions - the torque on the studs/nuts isn't huge so it doesn't tend to deform.
As long as it has been fitted 'dry' and not with any sealant, and looks undamaged, I'd give it a go.
(but if you'd said yesterday I would have stuck a new one in with the manifold which I sent off this morning :roll: )
If you do need a new one, I got mine from Rock Auto as I was getting some other stuff at the time - the unit price is only £2.36, but shipping is £16.56 :shock:
Worthwhile if it is part of a bigger order, otherwise it's SJs at £15.42 + VAT & delivery..... so a £2 part will cost you £20 whichever way you look at it :shock: :shock:
Edit - a 'split' of a set with someone else is probably a good idea - the HG is probably scrap anyway, and there will be some other bits in there worth having - notably the camshaft end seals, cam cover gasket, and valve stem seals...
Re: Gaskets
Postby GeoffSmith » Thu 29.05.2014, 12:16
Pete, if you want them quick then give me a shout. You can replace them in slow time maybe doubling up with Neil on a Rockauto order.
Re: Gaskets
Postby dapinky » Thu 29.05.2014, 12:20
GeoffSmith wrote:Pete, if you want them quick then give me a shout. You can replace them in slow time maybe doubling up with Neil on a Rockauto order.
It's going to take a couple of days for the manifold to get there, but Rock Auto wont get them here in that time!!!!
Re: Gaskets
Postby epipete » Thu 29.05.2014, 13:43
Well, seeking a quote from SJs has resulted in them offering to supply at plus £50; so Geoff if you have them available I'd be grateful if I could pop over at the weekend and then join in with a Rockauto buy and backfill to you later.
Guys, if we are rockautoing then I need to look at what else I might need, but thoughts on how we go about this please
Pete
Re: Gaskets
Postby GeoffSmith » Thu 29.05.2014, 15:11
We're in!
Re: Gaskets
Postby Peter_W » Thu 29.05.2014, 19:42
epipete wrote:... do I need any others to refit the turbo? If so what?
There's the copper washers for the oil and water banjo fittings.
10 x 16 mm, and
12 x 18 mm
Peter_W
Re: Gaskets
Postby epipete » Sun 01.06.2014, 09:55
Geoff,
You have a pm.
Pete
Return to Engine
