Replacement sump and oil pickup?
Postby Lotus54 » Sun 08.06.2014, 01:46
After searching, it appears a new sump is not to be had anywhere off anything.
Is that still correct?
Also,is the oil pickup still avaliable?
Someone used a ton of silicone sealer on it previously, and of course it got in the screen (I hate that stuff).
I'm trying to clean it, but the hole to access is pretty small.guess I could cut it larger? (But I don't like second guessing the engineers)
I'd like to address this as soon as possible, the sump is off and the weather is fantastic!
mark
(USA)
1978 Benelli 750 sei, 1972 Benelli 175 Enduro, 2018 Beta Xtrainer 300
Lotus54
Re: Replacement sump and oil pickup?
Postby esprit888 » Sun 08.06.2014, 01:59
I have a brand new OEM pick up from Lotus and another short block engine which happens to have an oil pan connected to it :D , just across the water in Victoria, but if you want the oil pan you take the block with it :-D .
Lotus54 wrote:After searching, it appears a new sump is not to be had anywhere off anything.
mark
(USA)
esprit888
Postby Brit-Car-Nut » Sun 08.06.2014, 02:04
I have a good used sump available and I believe I have a NEW oil pickup.
I will send you an email tomorrow with a picture of the sump and confirm I can lay my hands on the pickup.
Postby m100sandra » Mon 09.06.2014, 07:23
I think the new sumps are available now, that's what I was told a few Months ago......
m100sandra
Postby Brit-Car-Nut » Tue 10.06.2014, 13:52
That is correct. Lotus have 2 in stock at £142.59 each
There are some good used ones around for £80.00 + postage.
Postby maz_r » Tue 10.06.2014, 15:26
Lotus have 1 in stock...... :oops:
(mind you, it was most of £200 :()
maz_r
Binary Bodger
Postby Brit-Car-Nut » Tue 10.06.2014, 15:29
Glad you got one...
They have 5 more on order, but the last order took over a year to fulfill.
Return to Engine
