Alternator Dead
Alternator Dead
Postby roy666 » Thu 06.06.2019, 19:57
Hi Guys - seems like my alternator has finally had it. Battery light stays on and volts steadily decreasing on the voltmeter, and dip way down when I turn everything on. Any advice on where to source one other than SJS or Kelvedon. Grateful for a pointer on a place that refurbs or is it possible to get a new lighter model. cheers Mike
roy666
Re: Alternator Dead
Postby Andy_J » Thu 06.06.2019, 21:28
Can't comment on other sources of alternators, but I can confirm having just bought an alternator from SJS it is larger that the Original alternator and does not go back in without cutting the little metal tang of the back of the engine, just above the sump
90H BRG SE 48,000 Miles
Andy_J
Re: Alternator Dead
Postby roy666 » Thu 06.06.2019, 22:00
Thanks Andy... you happy with it..good purchase? M
roy666
Re: Alternator Dead
Postby M100TURBOFR » Fri 07.06.2019, 16:49
Roy
Might be of help. I have noted following equivalents :
Magneti Marelli 054022713010 / 54022713
MAN 1015
M100TURBOFR
Re: Alternator Dead
Postby Brit-Car-Nut » Fri 07.06.2019, 17:09
For US/FED car owners, the alternator is the same as the DOHC Geo Storm "manual gearbox" REMY 14390 or DENSO 2100409. The "automatic gearbox" REMY 14391 listing is slightly larger but I have been told that with some aggravation, it can wrestled into place.
The Starter is the same as the Turbo Isuzu Impulse and the 1993 Geo Storm. It is the "gear reduction" version (without the "snout").
The ACDELCO 3231058 is on closeout sale at Rock Auto for $65.09
Remember, GEO was a GM product, so they will use GM part numbers. Re-builders will use the most common interchange for their listings.
Re: Alternator Dead
Postby Andy_J » Fri 07.06.2019, 20:04
Hi Mike. I still have not finished putting the Elan back together, so all I can say is it looks OK. I still need to finish putting the PS reservoir back in and then the alternator belt. Should have that done this weekend. so will report back once I have fired the engine
Andy_J
Re: Alternator Dead
Postby peteoddcar » Fri 07.06.2019, 21:33
Andy_J wrote:Can't comment on other sources of alternators, but I can confirm having just bought an alternator from SJS it is larger that the Original alternator and does not go back in without cutting the little metal tang of the back of the engine, just above the sump
That’s what I did - it’s not as awful as it sounds - belt adjustment / fitting is also a bit of a challenge with the bigger alternator.
peteoddcar
Re: Alternator Dead
Postby texas2201 » Wed 14.08.2019, 18:28
Brit-Car-Nut wrote:For US/FED car owners, the alternator is the same as the DOHC Geo Storm "manual gearbox" REMY 14390 or DENSO 2100409. The "automatic gearbox" REMY 14391 listing is slightly larger but I have been told that with some aggravation, it can wrestled into place.
Can I assume this Alternator will fit a UK car?
Re: Alternator Dead
Postby Brit-Car-Nut » Wed 14.08.2019, 21:11
To the best of my knowledge, those Alternators worked in M100s owned by others.
They fit fine and have the correct pulley on them. They were purchased through different retailers including Rock Auto, and nobody needed to return anything.
Re: Alternator Dead
Postby texas2201 » Thu 15.08.2019, 05:55
Brit-Car-Nut wrote:To the best of my knowledge, those Alternators worked in M100s owned by others.
Thanks - how is life with you?
Re: Alternator Dead
Postby simonbuk » Thu 15.08.2019, 08:49
Try this bloke here -
ACW are based in Wimborne, Dorset BH21 2BZ. Tel no. 01202 885200
Very helpful over the phone, knows what car it is for as has sold them to other M100 owners. Very helpful chap.
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: Alternator Dead
Postby Rambo » Thu 15.08.2019, 09:09
But he has sold 4 duffers to 3 separate owners over the last 18 months. And 2 of them were to me :?
Re: Alternator Dead
Postby simonbuk » Thu 15.08.2019, 14:43
Oh. I was about to say that it was you who recommended him to me !!
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: Alternator Dead
Postby Rambo » Thu 15.08.2019, 19:53
I probably did but that was before I discovered 2 "buggert" ones. I suspect a bad batch of Chinese regulators/diodes ?? The 3rd seems to be holding up OK at present (different # ?)
Re: Alternator Dead
Postby simonbuk » Thu 15.08.2019, 23:09
So what was his after sales customer service like ?
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: Alternator Dead
Postby Rambo » Fri 16.08.2019, 08:18
Re: Alternator Dead
Postby texas2201 » Fri 16.08.2019, 10:51
Rambo wrote:I probably did but that was before I discovered 2 "buggert" ones. I suspect a bad batch of Chinese regulators/diodes ?? The 3rd seems to be holding up OK at present (different # ?)
seemed very helpful - hope mine is OK .....
Re: Alternator Dead
Postby simonbuk » Fri 16.08.2019, 21:11
Rambo wrote::?
Oh.
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: Alternator Dead
Postby peter123 » Wed 21.08.2019, 18:49
Well it looks like my alternator has now gone, it is showing over 16 volts on the car volt meter with the engine running, when i checked it with a multimeter it is putting out 17.8 volts, this one is a replacement to the faulty first one from the same person Rambo got his from, he was called Soss29 on Ebay but no longer seems to sell on there i am assuming this is the same person in Simonbuk's post.
Looks like i might have to order an alternator repair kit! :shock:
peter123
Re: Alternator Dead
Postby Rambo » Wed 21.08.2019, 19:45
Peter - it looks like we both got alternators from the same guy and the same duff batch !!!!
There were quite a few people on here (ab2cv, Simon.....) round about the same time who also bought alternators so these will no doubt turn out to be duffers too :?
Return to Engine
