Andy_J wrote:Can't comment on other sources of alternators, but I can confirm having just bought an alternator from SJS it is larger that the Original alternator and does not go back in without cutting the little metal tang of the back of the engine, just above the sump
Brit-Car-Nut wrote:For US/FED car owners, the alternator is the same as the DOHC Geo Storm "manual gearbox" REMY 14390 or DENSO 2100409. The "automatic gearbox" REMY 14391 listing is slightly larger but I have been told that with some aggravation, it can wrestled into place.
The Starter is the same as the Turbo Isuzu Impulse and the 1993 Geo Storm. It is the "gear reduction" version (without the "snout").
The ACDELCO 3231058 is on closeout sale at Rock Auto for $65.09
Remember, GEO was a GM product, so they will use GM part numbers. Re-builders will use the most common interchange for their listings.
Brit-Car-Nut wrote:To the best of my knowledge, those Alternators worked in M100s owned by others.
They fit fine and have the correct pulley on them. They were purchased through different retailers including Rock Auto, and nobody needed to return anything.
Rambo wrote:I probably did but that was before I discovered 2 "buggert" ones. I suspect a bad batch of Chinese regulators/diodes ?? The 3rd seems to be holding up OK at present (different # ?)
Rambo wrote::?
